Deacon 1357 Report post Posted February 25, 2017 7 minutes ago, Rich said: Bumpy section, downhill into cascades (left hander in the middle of the circuit)? Or maybe down the hill into knickerbrook (right left chicane)? Both of these sound quite plausible! Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 27, 2017 Thought I'd give a bit of an update on the upgraded brake set up I had fitted. The upgrade was a set of stoptech centric discs, project mu hc800+ pads, Hel lines and ferodo dot 5.1 fluid. I already had a set of 911 gt3 brake ducts fitted too. For normal road use the brakes are definitely not as sharp as the stock set up which is mainly due to the pads needing a bit more temperature to get working properly. At Oulton Park on Friday the brakes obviously got far more of a workout. Project mu talk about how progressive the brakes are in their literature and this is definitely true - much more so than the stock set up IMO. The initial travel on the pedal does not equate to the same level of braking that the stock set up gives feeling less 'assisted' than the stock set up but when you're further into the pedal travel the stopping power is very good. This seems to be an excellent set up for track work and trail braking as there is much more progressive braking to play with before hitting the 'meat' of the stopping power. I must admit though that I'm not 100% sold on it for my personal taste - I think I prefer the more linear feel of something like the stock set up. However this may just be a case of being very used to the stock set up after 4 years and something different feeling odd. I experienced no brake fade at all on any of the sessions I ran (max 20 mins) but obviously the weather wasn't the greatest - it'll be interesting to see how they hold up on a hotter, drier day which will place more demands on them. 1 Lauren reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted February 27, 2017 Did you notice much difference from the GT3 brake ducts? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 27, 2017 21 minutes ago, Rich said: Did you notice much difference from the GT3 brake ducts? It's hard to say on their own. They've been on for about a year but until Oulton I'd only done sprints which obviously don't really tax the brakes much. For the price they seem a bit of a no brainier to be honest. Share this post Link to post Share on other sites
Ade 517 Report post Posted February 27, 2017 2 hours ago, Deacon said: Thought I'd give a bit of an update on the upgraded brake set up I had fitted. The upgrade was a set of stoptech centric discs, project mu hc800+ pads, Hel lines and ferodo dot 5.1 fluid. I already had a set of 911 gt3 brake ducts fitted too. For normal road use the brakes are definitely not as sharp as the stock set up which is mainly due to the pads needing a bit more temperature to get working properly. At Oulton Park on Friday the brakes obviously got far more of a workout. Project mu talk about how progressive the brakes are in their literature and this is definitely true - much more so than the stock set up IMO. The initial travel on the pedal does not equate to the same level of braking that the stock set up gives feeling less 'assisted' than the stock set up but when you're further into the pedal travel the stopping power is very good. This seems to be an excellent set up for track work and trail braking as there is much more progressive braking to play with before hitting the 'meat' of the stopping power. I must admit though that I'm not 100% sold on it for my personal taste - I think I prefer the more linear feel of something like the stock set up. However this may just be a case of being very used to the stock set up after 4 years and something different feeling odd. I experienced no brake fade at all on any of the sessions I ran (max 20 mins) but obviously the weather wasn't the greatest - it'll be interesting to see how they hold up on a hotter, drier day which will place more demands on them. Something doesn't sound right to me. Once they are bedded in and warm/hot they offer a lot more initial bite than the stock pads. iirc. This "initial travel" is either the pads not bedded properly or something else like air in the system. Pedal should only start "sinking" under hard braking when they start to fade. They'll be smoking at that point. I get this issue with my cosworth brakes. Driving on public roads they dont get enough of a workout and come the trackday, it takes me the first couple sessions to get the initial sharpness back. Not saying that it the issue, but I distinctly remember loving the initial bite they gave (once bedded in), and going back to stock after them it felt distinctly lacking in bite/friction and a lot more pedal travel to lock the wheels. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 27, 2017 4 minutes ago, Ade said: Something doesn't sound right to me. Once they are bedded in and warm/hot they offer a lot more initial bite than the stock pads. iirc. This "initial travel" is either the pads not bedded properly or something else like air in the system. Pedal should only start "sinking" under hard braking when they start to fade. They'll be smoking at that point. I get this issue with my cosworth brakes. Driving on public roads they dont get enough of a workout and come the trackday, it takes me the first couple sessions to get the initial sharpness back. Not saying that it the issue, but I distinctly remember loving the initial bite they gave (once bedded in), and going back to stock after them it felt distinctly lacking in bite/friction and a lot more pedal travel to lock the wheels. Cheers @Ade. I'll keep my eye on it and maybe get @Riceburner to check it out when it's in for it's service and MOT soon. Share this post Link to post Share on other sites
Rich196 103 Report post Posted February 27, 2017 1 hour ago, Rich said: Did you notice much difference from the GT3 brake ducts? I fitted this as a mod in isolation. I fitted the GT3 ducts and remove the disc backing plate. Same pads and discs, and it made a noticeable improvement to me! Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 8, 2017 So after a few weeks with the stock exhaust and the JDL catted manifold on I've decided it's a bit too quiet so a new exhaust has been ordered and should be here in the next day or two. I've also had my winter wheels refurbished as 1. I didn't like the chrome and 2. As I'd expected the chrome didn't like the salt on the roads. I haven't actually picked them up yet and so obviously they're not on the car yet but here's a teaser:- Just a touch different to the chrome 😁 6 Keethos, Mark-in-Stoke, rob275 and 3 others reacted to this Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 8, 2017 Bat-mobile colour scheme 1 Deacon reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted March 8, 2017 Good news on the wheels. As you know I never liked the chrome. At least with a powder coat they don't seem to get affected by salt or brake dust, so it makes them dead easy to clean. 1 Deacon reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted March 8, 2017 The silver bit on my wheels haven't coped that well in the winter. Powder coat next year me thinks. Share this post Link to post Share on other sites
TTR 509 Report post Posted March 8, 2017 1 hour ago, Ade said: The silver bit on my wheels haven't coped that well in the winter. Powder coat next year me thinks. Bronze Share this post Link to post Share on other sites
rob275 1817 Report post Posted March 8, 2017 They will look great against the black me thinks! 2 Deacon and Mark-in-Stoke reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 8, 2017 2 minutes ago, rob275 said: They will look great against the black me thinks! Fingers crossed 1 Ade reacted to this Share this post Link to post Share on other sites
Mark-in-Stoke 488 Report post Posted March 8, 2017 Real nice red, Jeff 1 Deacon reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 8, 2017 1 hour ago, Mark-in-Stoke said: Real nice red, Jeff It's the 911 GT3 RS wheel red @Mark-in-Stoke 2 Mark-in-Stoke and Lauren reacted to this Share this post Link to post Share on other sites
Mark-in-Stoke 488 Report post Posted March 9, 2017 I'm looking forward to seeing them close up. Mine are being done at the moment too, must be the season for it 😁 1 Deacon reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 9, 2017 1 hour ago, Mark-in-Stoke said: I'm looking forward to seeing them close up. Mine are being done at the moment too, must be the season for it 😁 What colour you getting done mate? Share this post Link to post Share on other sites
Mark-in-Stoke 488 Report post Posted March 9, 2017 I've gone for a light anthracite, loved the colour sample but will wait until I see it on the wheel before knowing if I've made the right decision or not, so fingers crossed. 1 Deacon reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 12, 2017 While I'm on the stock exhaust and still on the track wheels, one thing that has become quite noticeable is the road roar from the Cup 2's - it's quite bad! Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 14, 2017 New exhaust arrived today. It's the HKS HiPower Spec L with black carbon tips. HKS have recently revised the design a little so it's now listed as 90db with the carbon tips. This should work nicely with the JDL manifold to keep me track noise limit friendly. I'll hopefully get it fitted in the next few weeks and I'll post up some video clips when it's on. Few pictures for now:- Thanks to @James@Amber for the excellent service as always 👍 Once this is fitted I'll also (finally) be able to get the centre Valenti light fitted too. 4 AJ124, Ztox, Keethos and 1 other reacted to this Share this post Link to post Share on other sites
DanJ 374 Report post Posted March 14, 2017 New exhaust arrived today. It's the HKS HiPower Spec L with black carbon tips. HKS have recently revised the design a little so it's now listed as 90db with the carbon tips. This should work nicely with the JDL manifold to keep me track noise limit friendly. I'll hopefully get it fitted in the next few weeks and I'll post up some video clips when it's on. Few pictures for now:- Thanks to @James@Amber for the excellent service as always 👍 Once this is fitted I'll also (finally) be able to get the centre Valenti light fitted too. Great choice, I have the same one and very pleased with it. 1 Deacon reacted to this Share this post Link to post Share on other sites
Cerastes 204 Report post Posted March 14, 2017 Looks good. Tempted. *Checks amber performance for the price* I just ordered my side lights and filter from them too. Must resist!!! Share this post Link to post Share on other sites
Guest Report post Posted March 15, 2017 Looks bloody awesome. I had a similar HKS exhaust setup on my Altezza with the resonance chamber, it worked a treat for getting rid of annoying exhaust notes. Very quiet though! Share this post Link to post Share on other sites
Bfranklyn86 52 Report post Posted March 15, 2017 That's a lovely exhaust. Do you know what the pipe diameter is? 1 Deacon reacted to this Share this post Link to post Share on other sites
