Leeky 84 Report post Posted June 3, 2019 Hey all, two quick questions that I couldn’t find a clear answer on. Hoping you guys could help me get to answers please? 1. When using FI on the FA20 what is considered to be the real tipping point where you really start to risk bending a rod? Cosworth appear to say 280bhp at the flywheel is as high as they recommend you should go on a stock engine. But does anyone have any experience or has heard of rods bending below this level of power? 2. Which FA20 supercharger has the best whine? I know there is a lot more to supercharging your 86 than just how it sounds, but whine on a supercharger is a glorious thing. I’ve seen the MRT video for their Sprintex charger which is the best i’ve heard so far. Is this generally considered to be the one with the best whine? Cheers! Share this post Link to post Share on other sites
will300 812 Report post Posted June 3, 2019 This seems like a good excuse for a good old whine... 😁 1 Leeky reacted to this Share this post Link to post Share on other sites
Rich196 103 Report post Posted June 3, 2019 sprintex is the only one that really wines. 1 Leeky reacted to this Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 3, 2019 Heres to hoping the last if the cosworths don't sell out before I get a chance to buy oneSent from my CLT-L09 using Tapatalk 1 Leeky reacted to this Share this post Link to post Share on other sites
Leeky 84 Report post Posted June 3, 2019 Cheers guys. So what you say confirms what I suspected SC whine wise from all the time i’d spent googling. So I just need to decide whether I wanna go Cossie Charger or if its worth paying the extra for the Sprintex whine. Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted June 3, 2019 I think I saw somewhere that a one let go at less than ~280 bhp, and I forget whether it was a turbo or not, but at least there's a sticker for that: https://mightycarmods.com/collections/stickers/products/rodney-the-piston-sticker Boost shortens the life of the engine unless it's designed for it or otherwise overengineered, so you shouldn't expect miracles, but supercharging at low boost is probably the least risky version of FI. 1 Leeky reacted to this Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 3, 2019 Cheers guys. So what you say confirms what I suspected SC whine wise from all the time i’d spent googling. So I just need to decide whether I wanna go Cossie Charger or if its worth paying the extra for the Sprintex whine.Wouldn't go for a sprintex. Abbey have stop using em over issues with heat managementSent from my CLT-L09 using Tapatalk 1 Leeky reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted June 3, 2019 Sprintex is outdated and was the first SC setup for this car. Has great mid-range but not so hot at the top end. It does whine pretty well though. The water/air intercooler is fairly limited in it's capacity though. Cosworth don't do the kit anymore, but Harrop is pretty similar. Doesn't really whine though. HKS is my favourite from a driving perspective but some issues over reliablity potentially and expensive parts may put you off. Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 3, 2019 Sprintex is outdated and was the first SC setup for this car. Has great mid-range but not so hot at the top end. It does whine pretty well though. The water/air intercooler is fairly limited in it's capacity though. Cosworth don't do the kit anymore, but Harrop is pretty similar. Doesn't really whine though. HKS is my favourite from a driving perspective but some issues over reliablity potentially and expensive parts may put you off. Still acouple cosworths floating around from other vendors lol. But if they're all gone by then it's harrop for meSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
DevilsCry 11 Report post Posted June 4, 2019 MIne's got Harrop's and it does not really whine. Share this post Link to post Share on other sites
Adam9 37 Report post Posted June 4, 2019 15 hours ago, nerdstrike said: I think I saw somewhere that a one let go at less than ~280 bhp, and I forget whether it was a turbo or not, but at least there's a sticker for that: https://mightycarmods.com/collections/stickers/products/rodney-the-piston-sticker Boost shortens the life of the engine unless it's designed for it or otherwise overengineered, so you shouldn't expect miracles, but supercharging at low boost is probably the least risky version of FI. I've seen a couple let go with no boost at all, its a total lottery. Some of the US cars are running 400+ bhp on stock rods and I think the TD dev car is currently running ~380bhp on a stock engine. 1 Leeky reacted to this Share this post Link to post Share on other sites
Kaltorak 111 Report post Posted June 4, 2019 The problem isnt as simple as at X BHP a rod will go. I got speaking to Mike at TD, he was explaining it was more about peak cylinder pressure. This is something that Supercharging has an advantage over turbo as it increases in a linear fashion where a turbo nowadays can push to max boost early on in the rev range. As the car revs up the peak cylinder pressure naturally drops off. The rods are also sintered which produces an irregular output hence why it is a lottery. 1 Leeky reacted to this Share this post Link to post Share on other sites
Leeky 84 Report post Posted June 4, 2019 Cheers all. Really good information here. Appreciate it! Share this post Link to post Share on other sites
Kodename47 446 Report post Posted June 4, 2019 19 hours ago, matrixprotein said: Abbey have stop using em over issues with heat management Only really an issue on track. Still enjoy mine after 4+ years boosted. The charge temps do get hotter than the rest but it is relative, the newer SPS version is apparently better and adds a little extra boost per pulley. The problem is that the cost of a new one means that often people will go to other alternatives, just look at the current discount of the clearance CW or how good value the TD turbo kit is. The Harrop, also being from Aus, is equivalent in price and produces "better" results and does have better heat management. For a road driven car the Sprintex is just fine. 70mm pulley it makes a lovely whine and puts out similar power to the Cosworth - I reckon mine is ~250-260 hub bhp, so right at the limit of what most would consider "safe". If I were to track it, the output would drop a bit over time as the W2A system heats up, but I'm still not sure it would ruin my fun. A WMI kit soon sorts that out. Share this post Link to post Share on other sites
Church 209 Report post Posted June 4, 2019 7 hours ago, DevilsCry said: MIne's got Harrop's and it does not really whine. Then install aftermarket gearbox/tranny/diff bushings, so that other parts will whine in place of quiet supercharger 1 nerdstrike reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted June 7, 2019 The Sprintex definitely has the best whine, its sound is completely infectious. I had one on my CR-Z and it's an excellent linear unit and pretty bomb proof.There is no doubting that it gets hot, though. Once I got a vented bonnet then the problem went away, as plenty of cool air flowed over it and boost didn't drop even in the hot summer.Sent from my LG-Q6 using Tapatalk Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 7, 2019 The Sprintex definitely has the best whine, its sound is completely infectious. I had one on my CR-Z and it's an excellent linear unit and pretty bomb proof.There is no doubting that it gets hot, though. Once I got a vented bonnet then the problem went away, as plenty of cool air flowed over it and boost didn't drop even in the hot summer.Sent from my LG-Q6 using TapatalkHow do you even clean a car with a vented bonnet xdSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
MartinT 514 Report post Posted June 7, 2019 You can spong and jetwash it as long as you don't point straight into the vents. I had the Seibon bonnet painted the same colour as the car. It looked gorgeous. 4 BRZ-123, spikyone, matrixprotein and 1 other reacted to this Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 11, 2019 I was just watching the harrop video. Putting all forged internals aside, they reduced pulley size and got the car up to 380bhp. I know cosworth do their 10% smaller pulley but is it simply reducing its size that's required to get additional boost?Sent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
Lauren 2259 Report post Posted June 11, 2019 29 minutes ago, matrixprotein said: I know cosworth do their 10% smaller pulley but is it simply reducing its size that's required to get additional boost? Sent from my CLT-L09 using Tapatalk Yes it is or over-sizing the crank pulley is the other way. The tough issues is insuring that the intercooling is up to the job as there will be increased heat generated especially if you start to over drive the supercharger. Share this post Link to post Share on other sites
sam534 62 Report post Posted June 12, 2019 Yeah bit of a lottery is seams, I have two friends who's NA cars let go. Sent from my STF-L09 using Tapatalk Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted June 12, 2019 There's a video thats on YouTube just been uploading by some Aussies. Who have had their rods go at about 400bhp. Pretty interesting watch as they take apart the engine and show you.If I remember where on YouTube I'll post a link.I know I'll go supercharger route but thought hmm if I went harrop and eventually wanted more power to do internals and then ask if harrop could make their smaller pulley. Haha now I'm dreamingSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
Church 209 Report post Posted June 12, 2019 One thing is minding engine only. Imho our engine should stomach some 300whp and higher without any strengthened components. But there is also tranny side. Very possibly at very least higher rated clutch won't hurt to not slip with increased torque, and stock gearbox .. was it 4th or 5th that granaded for several of higher boost builds? If one tracks car and has forced induction, i'd also think of BBK. I guess, cossy decided to limit boost with stock pulley exactly because much more accompanying mods at higher budget would be needed if one wants reliable / safe overall result. Share this post Link to post Share on other sites
Graham86 5 Report post Posted June 20, 2019 On 6/3/2019 at 10:24 PM, matrixprotein said: Still acouple cosworths floating around from other vendors lol. But if they're all gone by then it's harrop for me Sent from my CLT-L09 using Tapatalk I've bought a Cosworth kit from them direct, about a month ago. It's a very good kit and support. You do get some whine and can be heard fine with the stock exhaust. I've gone for the smaller pulley and there's no overheating issues. Share this post Link to post Share on other sites
Kaltorak 111 Report post Posted June 24, 2019 On 6/12/2019 at 12:00 PM, matrixprotein said: There's a video thats on YouTube just been uploading by some Aussies. Who have had their rods go at about 400bhp. Pretty interesting watch as they take apart the engine and show you. If I remember where on YouTube I'll post a link. I know I'll go supercharger route but thought hmm if I went harrop and eventually wanted more power to do internals and then ask if harrop could make their smaller pulley. Haha now I'm dreaming Sent from my CLT-L09 using Tapatalk High performance academy? Had it go while testing their anti lag. Share this post Link to post Share on other sites
