Deacon 1357 Report post Posted October 29, 2018 Collected my car today from Rogue Motorsport after having a few bits done including a custom airbox for the HKS filter to prevent the heat soak it suffered being an open filter. The box is wrapped in heat protective material on the bottom half and after an approx 70 mile drive was barely lukewarm so seems to be doing its job well. 2 shiftspark and Lowe reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted November 11, 2018 While the car was at Rogue Motorsport they also made me a manifold/overpipe combo to try along with a new sports cat pipe with an extra resonator added. It's a work of art and seems a massive shame for it to be hidden away under the car! And a picture on the car showing the sports cat and resonator section too 4 Ccolleavy, smudge, will300 and 1 other reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted November 11, 2018 After I collected the car I took it up to Mike and TD for him and Nick to work their magic on the mapping. My car has always dyno'd pretty low but the gains the new manifold and intake set up have made are pretty significant even over the decent gains the JDL had made. The torque dip is now a peak. One slightly unexpected thing is that the new set up has lost a little bit to the JDL set up around the 5.5-6.5k rpm range but then picks up again after that. The difference low down is very noticeable though especially in normal driving where you can really feel the extra power and torque. First dyno picture is the new set up against the JDL catless manifold, second is the new set up against the first set up I had dyno'd at td (Cobra non res catback, intake pipe, HKS panel filter and EcuTek map) 2 1 Lauren, spikyone and BRZ-123 reacted to this Share this post Link to post Share on other sites
