Mike@TD.co.uk 467 Report post Posted June 16, 2016 Hello all, We've decided to put together a package for those wanting to release more power from their GT86 or BRZ, without going for forced induction The kit contains the following: 'Before' Dyno Run Tuning Developments Manifold (EL or UEL) Tuning Developments Overpipe Gaskets Heat Wrap For 'Downpipe' Section K&N 'Drop In' Replacement Panel Filter Installation ECUTeK License In House Remap On The Dyno £1495.00 inc VAT Website link here This package has been proven to remove the torque dip which plagues these cars, along with making more peak power. The whole curve is stronger, making the driving experience much more enjoyable! The ECUTeK Remap features the excellent RaceROM which gives you 4 switchable maps via the cruise control stalk which can be adjusted whilst on the fly. For those without cruise control we can set this up via the heated rear window button. Net gains are upto 30lb.ft through the mid range and upto 25bhp peak power (based against a 100% factory car). You do not have to have an aftermarket exhaust, this is completely optional. The second CAT can also stay in place if needed. This gives an end result of a car that when cruising, sounds very close to OE sound levels, and has a pleasant bark to it when pressing on through the gears. The gains in torque make it much nicer to drive and give a far more linear delivery. The top dyno graph has the factory second CAT and factory exhaust. The lower dyno graph has a high flow second CAT and an aftermarket exhaust. Above - TD EL Manifold, Full Exhaust & In House ECUTeK Tune (Didn't photo the overlay from before sorry!) Above - Exhaust & ECUTeK Tune - Versus TD UEL Manifold & In House ECUTeK Tune. Above - Exhaust & Stock Tune - Versus TD EL Manifold & In house ECUTeK Tune. Above - Full Exhaust & Tomei Manifold & ECUTeK Tune - Versus Full Exhaust & TD EL Manifold & In House ECUTeK Tune Noise testing data This Package (UEL Manifold) Stock Second CAT Our Resonated CAT Back Exhaust @4500rpm static test is 89db. Gives a lovely bark when pushing on yet subtle when cruising. When we have an EL setup in we will do the same test. This Package (EL Manifold) Stock Second CAT Stock CAT Back Exhaust @5000rpm static test is 84db. Feedback: Some of the feedback from the NA Tuning Package. Any questions, drop me a PM on here, email me on mike@tuningdevelopments.co.uk or give me a call on 01925 822 266. Thanks Mike 6 Andrew Smith, Rich, Tristor and 3 others reacted to this Share this post Link to post Share on other sites
S18 RSG 429 Report post Posted June 16, 2016 Amazing value Mike, this should be a no brainer for anyone. I spent around the same money buying similar parts, except I had the hassle of importing parts from the US and having the manifold fitted by a non-GT86 specialist, so this is a truly great price. If only you had this available when I bought my car. 3 Tareim, Mike@TD.co.uk and Angelina reacted to this Share this post Link to post Share on other sites
Will T8WMM 28 Report post Posted June 16, 2016 You are fast becoming my favourite GT86/BRZ specialists. Great package, tempted to jump on this then follow up with the turbo a little later. 2 Mike@TD.co.uk and Angelina reacted to this Share this post Link to post Share on other sites
Nicebiscuit 655 Report post Posted June 17, 2016 Once you've felt the power of his package, it's hard to go back... (God, I'm so childish... ) Sent from my iPhone using Tapatalk 2 Test Drives Unlimited and Kirsty80 reacted to this Share this post Link to post Share on other sites
long-gone 152 Report post Posted July 26, 2016 In. Order placed. 2 Mark-in-Stoke and Will T8WMM reacted to this Share this post Link to post Share on other sites
