LeviDane 14 Report post Posted February 25, 2018 Me and a friend found a private area today, just long enough to do a lil pull on. His car is completely stock and mine has tuning developments EL, overpipe and miltek exhaust with a tune. A good visual on the difference it makes. We did many pulls and even switched cars. The difference is noticeable. Next i want to get some 0-60 times. I need some new wheels though i am on stock ones which lose grip so easily. Tuned GT86 vs Stock GT86 3 1 Lowe, Mike@TD.co.uk, VAD17 and 1 other reacted to this Share this post Link to post Share on other sites
alucardo 55 Report post Posted September 1, 2018 TD resonated cat back, manifold and downpipe if any of you where wondering what it sounds like 2 Mike@TD.co.uk and Luke reacted to this Share this post Link to post Share on other sites
