VAD17 479 Report post Posted July 6, 2019 On related topic I had KSports kit now for over 1.5yrs, 10k road miles, dozen or so track days (plus carlimits, pistonheads at Silverstone and even an action day). Used ECB Yellowstuff pads, now on Bluestuff. After replacing pads before the last track day at Brands ended up with fairly noticeable vibration under heavy braking (particularly into the Paddock Hill bend from 115+ mph). Probably have not bedded pads properly so now a bit of pad material residue on the disks that does not come off (tried couple times on the m-way to re-bed), so the disks need to be skimmed. The disks themselves show decent amount of wear, probably more than I would expect, but then I do overbrake so for others they could last longer. This said I expect they should last at least another year, which would take them to 15+k miles and about 20 track days in total. I had a quick look at price for new 356mm disks - Raylands (J-hook style) would do them for £295, MTEC replacement (grooved) will be £290, KSports original disks from GSM Performance (grooved) £387. I also don't think pads prices are materially different, I have previously confirmed that the pad size is the same as for one of AP calipers and then doing quick google compare it was not that much of a difference. I did like Yellowstuff, although the way I drive they last about 6-7 track days, but they are quiet and very good from cold, not too dusty either. I am yet to form my opinion of Bluestuff but they are certainly better when hot, ok from cold, but dustier, and I expect they would be wearing disks faster as well. 2 spikyone and Luke reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted July 6, 2019 I've had my AP four pots on with Reyland grooved discs and DS2500 pads on for over a year and a half now. Done nearly 30K miles on them, about five or six track days, about ten sprints. The pads still have a good amount of meat on them and the discs look hardly worn. Amazing really. Feels like they'll last forever, but reckon I'll get another 10K miles out of them pretty easily. I should add though that my pads tend to last a lot longer than average as I am pretty easy on the brakes. Obviously on track I do use them to their full capacity, especially so on sprints where every hundredth of a second counts, so there's no early braking at all. On the road I brake as little as possible, which probably helps me get great mileage out of them. On stock pads and discs I would get around 37K miles out of them. 3 Luke, VAD17 and spikyone reacted to this Share this post Link to post Share on other sites
will300 812 Report post Posted July 6, 2019 To echo @Lauren's comment, I've had my Reyland AP kit on for two and a half years now and probably done a about 10 track days since and about 25k road miles, without any concerning issues (I've had some debris scratch the disc's and hats & boiled brake fluid - but both will happen with any brake (OEM or BBK) setup). I'm still on my original AP disc's, which have lasted incredibly well, I'm sure if I ran a more aggressive pad compound they'd get used up alot quicker. I also changed my brake pads around 9 months ago, purely to try a slightly different compound to the previous pads, Ferrodo's DS2500 as provided with the kit. The Ferrodo's still have a good amount of meat left on them and I'll be switching back to them in a couple of weeks for several upcoming track days. The Reyland big brake kit has been my joint best mod to the car, with the exhaust manifold being the other. 3 spikyone, Luke and VAD17 reacted to this Share this post Link to post Share on other sites
Kodename47 446 Report post Posted September 3, 2019 10 hours ago, Luke said: Every big brake kit that I've seen for sale has never mentioned that it moves the bias forwards or backwards at all. That's because the well designed kits aren't designed to shift bias. You use piston area and disc size to maintain the balance, a BBK isn't primarily for improved braking distances, it's to get the heat out the system for longevity. 3 1 Lauren, Church, TommyC and 1 other reacted to this Share this post Link to post Share on other sites
Church 209 Report post Posted September 4, 2019 gavin_t:Slowing from speed A to speed B is to convert specific amount of kinetic energy into heat via brakes, that amount won't change if you do it quicker or slower over longer distance. And there can be both more heat from braking later/heavier (and thus quicker laptimes due accelerating longer elsewhere and higher speeds to bleed/more kinetic energy (which changes square of speed btw) to brake) but also it can be better cooled off (longer driving without braking, more cooling at higher speeds, better heat dissipation from hotter brakes vs ambient temps). Newbies imho often overheat brakes more because they may drive with nannies like SC/ABS/EBD/ediff, that may add up brake use/wear/heat when trying to correct car behaviour via actuating brakes. Imho issues with stock brakes for some on track working worse might be like using too sticky tires (or too much aero, also increasing grip) overcoming max brake torque, and using too street oriented pads with little friction Mu, thus due harder pressing brakes needed it robs from fine-control of brakes. Both can be improved/fixed with right pads for specific use (unfortunately compromising daily driveability noise/dust/cold-stops wise). What pads & better brake fluid won't fix - max heat capacity and cooling efficiency. But if one operates within these known limitations, there is nothing wrong with using stock brakes on track. For exampl-NA car (as forced induction = faster speeds/more kinetic energy (square of speed) = much more heat in brakes) on not too sticky tires and track sessions not longer then 10-15min (fine by me. I often start to loose top concentration past 15min tracking anyway). Also brake cooling ducts can be added (or even electric fans. saw such kit made by ausies, engaging according to temp probe readings) to get more from stockers if wished so. If pads fit well to one's use, recall CSG Mike writing: "As a rule of thumb, if you're getting 4 days out of a pad, you're pad is roughly matched to your setup/driving/experience on the FRS/BRZ. If you're getting more, you should stay where you are, or possibly move down a compound, depending on wear. If you're getting less, you need to move up compounds, and/or get a BBK, and/or get ducting." After all, stock brakes on our cars are not exactly very bad (fronts AFAIK were from wrx, rears - legacy gt), and there are cars with worse stock brakes (eg. heard that S2000 are a bit more underbraked, requiring even more uprated pads). And big bonus of stock brakes - better clearance of small wheels (for eg. winter) and also legality wise (country specific, but eg. in LV to be MOT legal only manufacturer official options can be considered (for example PP brembos), otherwise - just pads/fluid/ducts and very limited number of homologated brake lines, of course one can twice a year change to aftermarket BBK and back to stockers, but i don't want to consider that as option ). Share this post Link to post Share on other sites
