Mike@TD.co.uk 467 Report post Posted October 4, 2019 Afternoon all, We're going to run an offer for October on our NA Tuning Package Gains of upto 25hp & 40lb.ft through the midrange and 20hp peak at high RPM, transforms the drive of the 86/BRZ platform! Just to recap, the kit consists of: 'Before' Dyno Run Tuning Developments Manifold (EL or UEL) Tuning Developments Overpipe Gaskets Heat Wrap For 'Downpipe' Section K&N 'Drop In' Replacement Panel Filter Installation ECUTeK License In House Remap On The Dyno Usually £1495.00, we're running this for £1350.00 for the month of October only. Must be booked in and the work carried out during October To book in, please either drop me a message via this forum, drop me an email to mike@tuningdevelopments.co.uk or give me a call on 01925 822 266. Thanks! Mike 3 Angelina, VAD17 and willclarke reacted to this Share this post Link to post Share on other sites
mattt 29 Report post Posted October 4, 2019 Highly recommend this!Sent from my ONEPLUS A5000 using Tapatalk 1 Mike@TD.co.uk reacted to this Share this post Link to post Share on other sites
XK140 11 Report post Posted October 4, 2019 With this package,i.e. manifold and overpipe,what happens to the overall noise level if the rest of the exhaust is left standard? Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 4, 2019 14 minutes ago, XK140 said: With this package,i.e. manifold and overpipe,what happens to the overall noise level if the rest of the exhaust is left standard? Hi there, Idle and cruising there is next to no difference. When on full throttle/hard load there is a slight increase in exhaust volume. Thanks Mike Share this post Link to post Share on other sites
Hypnosis 12 Report post Posted October 4, 2019 Damn it! Why did I have to start buying a house?! Share this post Link to post Share on other sites
Driftrocker 5 Report post Posted October 4, 2019 Booked in for the 26th October, looking forward to feeling the difference. 2 ttjt16 and GT_86 reacted to this Share this post Link to post Share on other sites
GT_86 12 Report post Posted October 4, 2019 It’s well worth the money. Really transforms the car, glad I got mine done! Share this post Link to post Share on other sites
MartinT 514 Report post Posted October 4, 2019 Agreed, the NA kit makes the car a really good drive. Share this post Link to post Share on other sites
XK140 11 Report post Posted October 5, 2019 On 10/4/2019 at 2:28 PM, Mike@TD.co.uk said: Hi there, Idle and cruising there is next to no difference. When on full throttle/hard load there is a slight increase in exhaust volume. Thanks Mike Thanks,good to know that. Sorry to bother you again,but can I just ask what would be the effect on noise levels if at the same time as this mod the noise generator thingee was done away with by fitting the modified (closed) inlet pipe? Share this post Link to post Share on other sites
VAD17 479 Report post Posted October 6, 2019 Thanks,good to know that. Sorry to bother you again,but can I just ask what would be the effect on noise levels if at the same time as this mod the noise generator thingee was done away with by fitting the modified (closed) inlet pipe?Noise generator just creates cabin noise, removing it should have no impact on the noise level outside. I went for TD N/A package before going with TD turbo. Short of FI its probably the best mod for our cars.On N/A package noise level change very little, exhaust tone is somewhat different (lower/ deeper even in lower revs) - I liked it more.Sent from my SM-G973F using Tapatalk Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 7, 2019 On 10/5/2019 at 10:33 PM, XK140 said: Thanks,good to know that. Sorry to bother you again,but can I just ask what would be the effect on noise levels if at the same time as this mod the noise generator thingee was done away with by fitting the modified (closed) inlet pipe? No problem. The intake hose will remove the induction noise that is piped into the cabin on the standard car. Which should then make it slightly quieter. The intake hose does not affect the exhaust note. Thanks Mike 1 Angelina reacted to this Share this post Link to post Share on other sites
gavin_t 184 Report post Posted October 7, 2019 BARGIN ALERT! Still a bargain at full price so even better with this. I can confirm with the stock exhaust you get all the gains of the kit and the volume stays the same. Sounds the same at idle but with a bit of a different tone up the revs. Think I have some inside the cabin footage from track days in mine I can post if needed. (think mine still has the intake hose all connected up) Lots of other nice little touches gained as well like the removal of the cold start up and better mapping of the throttle pedal Couple of years down the line I still love mine and am glad I did it rather then jumping on the Forced induction band wagon straight away. Share this post Link to post Share on other sites
KevinA 695 Report post Posted October 7, 2019 I ran 2 years with the NA kit, and into my first year of FI. I can't fault either Share this post Link to post Share on other sites
Angelina 82 Report post Posted October 7, 2019 Nearly a year since mine was done, no regrets. Definitely recommend. 👍 Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 8, 2019 Appreciate the kind comments above Thank you to those who have booked in with us already, we do still have some availability left if there are any others tempted to save some money Thanks Mike 1 gavin_t reacted to this Share this post Link to post Share on other sites
CherryBomb 34 Report post Posted October 8, 2019 Ohh, I wish I could. Hopefully next October you'll have the same offer? Share this post Link to post Share on other sites
bassett 48 Report post Posted October 8, 2019 Hi, can you help with a few quick questions, is the deal any cheaper if you already have an ecutek licence and the car has been mapped previously all be it else where? Is the second cat as effective as the primary cat and will it still pass a regular mot? Thanks Adam Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 9, 2019 17 hours ago, bassett said: Hi, can you help with a few quick questions, is the deal any cheaper if you already have an ecutek licence and the car has been mapped previously all be it else where? Is the second cat as effective as the primary cat and will it still pass a regular mot? Thanks Adam Hi Adam, If you have an ECUTeK license then yes it will be £180.00 less on this deal. Many people still sail through with the second CAT, just ensure it is warm when tested. Thanks Mike Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 15, 2019 Good afternoon all, We have a couple of spaces free still during the last half of October should anyone else wish to remove their torque dip Thanks Mike Share this post Link to post Share on other sites
TomsGT86 2 Report post Posted October 18, 2019 Hi Mike, What days are the free spaces on? guessing the whole thing takes a few hours? Could a full 60,000 service be done at the same time? Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 18, 2019 28 minutes ago, TomsGT86 said: Hi Mike, What days are the free spaces on? guessing the whole thing takes a few hours? Could a full 60,000 service be done at the same time? Hi Tom, I've dropped you a PM. Thanks Mike Share this post Link to post Share on other sites
gavin_t 184 Report post Posted October 18, 2019 On 10/9/2019 at 4:17 PM, Mike@TD.co.uk said: Many people still sail through with the second CAT, just ensure it is warm when tested. Thanks Mike Yes mine has passed each year since it was fitted with my very fussy local MOT chap, Just need to ensure the car if nice and warm before hand as mike says Good excuse for a quick roundabout GP session and then make sure they stick it straight on the emissions rig Share this post Link to post Share on other sites
ttjt16 4 Report post Posted October 18, 2019 @Mike@TD.co.ukCould you post up the before and after dyno print outs for me? Thanks. Share this post Link to post Share on other sites
GravelRash 62 Report post Posted October 18, 2019 25 minutes ago, ttjt16 said: @Mike@TD.co.ukCould you post up the before and after dyno print outs for me? Thanks. This is my dyno sheet from when I had it done. Would I do it again? Yes. Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted October 18, 2019 34 minutes ago, ttjt16 said: @Mike@TD.co.ukCould you post up the before and after dyno print outs for me? Thanks. Hi there, Further to Mark's above, there are plenty on my instagram also https://www.instagram.com/miketuningdevelopments/ Thanks Mike Share this post Link to post Share on other sites
