Lmc 27 Report post Posted February 23, 2019 Looking to add a turbo kit to the car once the valve recall has been completed so just in the process of research. With that in mind does anyone have any experience/ opinions of the speed by design turbo kit? I’m well aware of the td kit but as I’m in the fortunate position of the car just being a weekend toy i would rather do the fitting myself & then just pay for tuning as opposed to just shelling over a lump of money & having zero involvement. I’m fairly sure that I’ve read that td aren’t interested in doing a supply only kit anyway so that kind of rules them out (which is a shame) Share this post Link to post Share on other sites
Lmc 27 Report post Posted February 24, 2019 I’m judging by the lack of response that no ones using the speed by design kit. Are everyone that goes turbo just sending there cars to TD? The hks kit looks like a good kit but more expensive than just sending the car to TD. Share this post Link to post Share on other sites
KevinA 695 Report post Posted February 24, 2019 Think you will find TD so popular is because they have fitted so many FI kits now, they know what they are doing and have proven results. Speak to Mike at TD and he will answer any questions you have. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted February 24, 2019 5 minutes ago, KevinA said: Think you will find TD so popular is because..... They are cheaper than the others. The most turbo kits fitted in the UK are probably AVO, but then TD came along at a better price point. However I prefer the turbo location of the AVO. 1 BRZ-123 reacted to this Share this post Link to post Share on other sites
matrixprotein 33 Report post Posted February 24, 2019 I'm gonna go supercharger. Once I ever get round to it. But like above mentioned I like where the avo sitsSent from my CLT-L09 using Tapatalk Share this post Link to post Share on other sites
BRZ-123 174 Report post Posted February 24, 2019 Speak to Jez at Horsham Developments. He has a Speed by Design turbo fitted to his GT86 and specialises in Nissans and the Toybaru Twins.. 1 Lmc reacted to this Share this post Link to post Share on other sites
surrey86 352 Report post Posted February 25, 2019 The Avo uses the OEM airbox unlike the other turbo kits, so draws in air from outside the engine bay, which is preferable. The turbos seem to be of lesser quality though. Share this post Link to post Share on other sites
GravelRash 62 Report post Posted February 25, 2019 18 minutes ago, maurice said: The Avo uses the OEM airbox unlike the other turbo kits, so draws in air from outside the engine bay, which is preferable. Turbo's will increase the incoming air charge far beyond the external ambient air-temperature and the kits will probably then be sending the loaded charge into the engine via a correctly sized and flowing intercooler. I doubt that the location of the air-filter makes any difference to the charge temperature at the point of entry into the engine itself. Share this post Link to post Share on other sites
surrey86 352 Report post Posted February 25, 2019 That's good to know. Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted February 25, 2019 1 hour ago, GravelRash said: I doubt that the location of the air-filter makes any difference to the charge temperature at the point of entry into the engine itself. Where do you suppose the energy comes from that makes the post-turbo air charge hot? It's proportionate to the temperature of the air coming into the turbo. Aside from a bit of soak from the impeller itself, it's mainly the compression that increases the temperature - see ideal gas law. The higher the starting temperature the more energy in the resulting compressed air, and the more effort it takes to compress. The intercooler can take 10 degrees or more out of the intake charge, but I don't believe the cooling efficiency increases with temperature as much as the heat of compression does. That's before you take into account the practical effects of a car that heatsoaks at idle and has to drain the engine bay of hot air, instead of just the intake volume. I've lost count of how many times I've seen people complaining about wobbly idles and erratic fuelling from replacing their intakes and filter boxes. Good air supply matters! At least to a point. NA ram-scoops have a tiny effect, and most cold air induction kits trade weather resilience for marginal improvements over OEM offerings. 2 1 GravelRash, TommyC and KAS reacted to this Share this post Link to post Share on other sites
Varelco 211 Report post Posted February 25, 2019 My 200sx used to suffer badly from heat soak during the summer. It is important as Nerdstrike says. Both the TD and Avo kit have their strengths and weaknesses it's down the personal preference but in short they are the most popular kits for UK cars. 1 1 sxocpaul and KevinA reacted to this Share this post Link to post Share on other sites
sxocpaul 49 Report post Posted February 26, 2019 On 2/25/2019 at 1:22 PM, Varelco said: My 200sx used to suffer badly from heat soak during the summer. It is important as Nerdstrike says. Both the TD and Avo kit have their strengths and weaknesses it's down the personal preference but in short they are the most popular kits for UK cars. Rare beast now days Share this post Link to post Share on other sites
