Lowe 191 Report post Posted October 15, 2018 Marmite time! Saw these for sale the other week and couldn't get down there quick enough to get them! They're the matching rear deck to my side louvres. Turns out it was Matt, the owner of MB Developments, a pretty well known Impreza breakers. He's got a BRZ as a personal car and these were from that. That said there wasn't much left of his own car To say it's undergoing a transformation would be an understatement. It was basically a rolling shell, everything back to bare metal in the most, and it had been attacked with an angle grinder. Rear arches cut away with wide arches being put in place. Custom made front wings with canards on too though none of that will be long term, since these are moulds for the carbon fibre panels that will go on once made. Oh, and there's a stinking great 2JZ in the front! This will be an absolute weapon when it's finished, I can't wait to see what it looks like in the end. Might be worth keeping an eye out for the company too since I guess they'll probably start doing more BRZ/86 platform stuff if the demand's there. Anyhoo, back to louvres. They were a little dusty since they'd been kept next to the BRZ when it was being fibreglassed so first port of call was a bloody good wash, and then layer of trim sealant to bring the black out a bit. That's when I took the above photo. Next job was removing all the old 3M tape that was stuck to the inner edge and the mounting brackets. This was a slow, slow process even with the careful use of sticky stuff remover. At this point I noticed one of the mounting brackets was missing and a couple of the rounded nuts were a bit damaged, so I managed to source some replacements along with fresh washers from Screwfix. Next step was to put some fresh 3M down. I decided to miss out the top two brackets since I was already one down and instead concentrate on some good thick 3M there. I put in a couple of water breaks along the top and bottom edges for good measure. Since I didn't have the original template for the brackets it would be a one shot deal on lining everything up once the 3M was peeled, so I placed the brackets into the louvres and finger tightened them up. My father in law gave me a hand fitting them, and we did a dry fit first to make sure everything was OK. The fit was spot on, so we used double glazing packers wedged in-between the glass and body to act as guides once we went for the final fitting. It worked pretty much spot on, lots of pressure and heat to help the 3M bite and then it was left in the garage overnight to cure. Rear visibility is obviously compromised, but not actually by all that much. The cabin is much darker though, especially in the back as you'd expect. Overall I'm really pleased. I know they're not to everyone's taste, yes they probably ruin airflow and add weight... but I think they look cool AF. 5 Deacon, Test Drives Unlimited, Samwise and 2 others reacted to this Share this post Link to post Share on other sites
Lowe 191 Report post Posted October 30, 2018 As @Kadaver mentioned I bought his old Maxton Design splitter the other day. Longer term I'm thinking of getting some of the Verus Engineering aero stuff, but given the price of it I wanted to be sure that I wasn't going to bin it after 5 minutes. So, my thinking is try this and see how I get on. If I don't smash it up after a few months due to having such a low front end, then the Verus parts are a worthwhile purchase. I tried a mock fitting with cardboard risers just to get an idea of what it'll look like. I think visually it'll help balance up the front end, since the rear is looking quite aggressive with all the louvres etc, but the front is just kinda... well, stock. I think I'm going to paint the tie rods black to hide them a little more, and I'll probably drill out the Maxton badge to keep that looking a bit more stealth. That brick of a numberplate holder needs to come off too. Wish I had a warm garage haha! 3 Deacon, Mark-in-Stoke and Kadaver reacted to this Share this post Link to post Share on other sites
Lowe 191 Report post Posted November 12, 2018 So the car went in to RRG for the big 60k service last Thursday. It was just before this the whole valve spring recall thing happened, and mine is one of the effected cars. Given that the work procedure is still unknown I asked if it was possible to do everything on the major service apart from the spark plugs, since I didn't see the point in having the engine lifted for the plugs only to have the same thing done again a month or so later for the springs. Every cloud and all that... Whilst it was there I had a couple of other bits done. I'd picked up a Cosworth baffle plate a few months back, purely as a peace of mind thing. I don't do track work, but do hammer around the country lanes on the odd occasion and knowing how prone to oil issues the FA20 is I figured for a couple of hundred quid it was probably worth it. I took the splitter up as well, and that got chucked on. A few pics I sprayed the rods black, but left the threads since for the moment I wasn't sure how far they'd need to be wound out. These will be touched in by hand when it's not chucking it down. Freshly fitted and ready for collection from RRG Macc Cleaned up a bit The tie rod silver bits are setting my OCD off and I think I'll probably remove the Maxton badge as well. More stealth. Need to get the front brick off and sort some fresh plates now I think. 2 sam534 and Mark-in-Stoke reacted to this Share this post Link to post Share on other sites
