DanJ 374 Report post Posted August 26, 2017 New (not so) shiny bits to be fitted. Should sound much less tractor esque now 6 HariboPenguin, TTR, Rich and 3 others reacted to this Share this post Link to post Share on other sites
DanJ 374 Report post Posted August 26, 2017 Manifold in-situ: 3 Deacon, Ade and TTR reacted to this Share this post Link to post Share on other sites
