Keethos 842 Report post Posted September 30, 2014 Seems like it. Share this post Link to post Share on other sites
Riceburner 284 Report post Posted September 30, 2014 We should Have the Yellow one by mid to late october Aero now due 15th Share this post Link to post Share on other sites
Mike 458 Report post Posted September 30, 2014 It does look good in Man Utd Red Share this post Link to post Share on other sites
Riceburner 284 Report post Posted September 30, 2014 Man City Away Shirt Colours Share this post Link to post Share on other sites
Captain Duff 79 Report post Posted September 30, 2014 The Primo actually looks as though it might be decent value to me given it doesn't appear to be anywhere near the same 'poverty' spec as the base model in Japan (or the Scion for that matter) - but I'm confused with the mention of hill start on the base model - is that now going to be standard through the range? Also, are the Sachs coilovers (assuming they are going to be used in the upgraded models) likely to be available as a separate stand-alone upgrade via the dealer network? They certainly look good on the German development car using stock wheels - Share this post Link to post Share on other sites
Mike 458 Report post Posted September 30, 2014 Man City Away Shirt Colours Purple? Share this post Link to post Share on other sites
Kodename47 446 Report post Posted September 30, 2014 The Primo actually looks as though it might be decent value to me given it doesn't appear to be anywhere near the same 'poverty' spec as the base model in Japan (or the Scion for that matter) - but I'm confused with the mention of hill start on the base model - is that now going to be standard through the range? Also, are the Sachs coilovers (assuming they are going to be used in the upgraded models) likely to be available as a separate stand-alone upgrade via the dealer network?The description of the Primo definitely sounds the same as the FR-S. No dual climate system, no HIDs, no spoiler. The FR-S isn't quite the same as the base model in Japan which has smaller wheels and brakes etc. They stated hill start assist when the original came out, possibly the same mistake?The Sachs probably won't be an upgrade, but no reason you couldn't just order them as parts. I wonder if it's just the shocks or anything else has changed as well. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted September 30, 2014 The Primo actually looks as though it might be decent value to me given it doesn't appear to be anywhere near the same 'poverty' spec as the base model in Japan (or the Scion for that matter) - but I'm confused with the mention of hill start on the base model - is that now going to be standard through the range? Also, are the Sachs coilovers (assuming they are going to be used in the upgraded models) likely to be available as a separate stand-alone upgrade via the dealer network? They certainly look good on the German development car using stock wheels - I doubt it's the sachs coilovers that are fitted. They have been available for a while as an aftermarket fitment. I'm pretty sure it's just dampers made by sachs on the 2015my. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted September 30, 2014 The description of the Primo definitely sounds the same as the FR-S. No dual climate system, no HIDs, no spoiler. The FR-S isn't quite the same as the base model in Japan which has smaller wheels and brakes etc. They stated hill start assist when the original came out, possibly the same mistake? The Sachs probably won't be an upgrade, but no reason you couldn't just order them as parts. I wonder if it's just the shocks or anything else has changed as well. I've seen the newer version from what I could tell at 86 style. It's just Sachs dampers from what I could see. They may well be an improvement over the standard dampers. Though if you're going to change for something aftermarket it matters little really. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted September 30, 2014 I've seen the newer version from what I could tell at 86 style. It's just Sachs dampers from what I could see. They may well be an improvement over the standard dampers. Though if you're going to change for something aftermarket it matters little really. I meant as in changes to things like LCA or anything else connected to the struts. Basically if this a direct easy swap over or a bit more involved. They were changed for a reason, the originals (Prova?) aren't of bad quality but I'd assume the new ones to be better. If my springs cause the dampers to go I'll contemplate swapping to these. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 1, 2014 Well, I didn't do any measurements but looked simply like a different damper and nothing else. 1 Kodename47 reacted to this Share this post Link to post Share on other sites
Riceburner 284 Report post Posted October 10, 2014 Its arrived Cant register it untill monday I will post pics after PDI & valeting on Monday Right Mod Number 1 Blitz intake.........!!! Number 2............. 2 GT86Jay and Keethos reacted to this Share this post Link to post Share on other sites
Mike 458 Report post Posted October 10, 2014 Number 2.. a loud chavvy exhaust? Share this post Link to post Share on other sites
Riceburner 284 Report post Posted October 10, 2014 Delivered By GOD this morning Share this post Link to post Share on other sites
Riceburner 284 Report post Posted October 10, 2014 Number 2.. a loud chavvy exhaust? How Dare you Mike,it will be a tuned system as usual,no cheap stuff 1 Mike reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 10, 2014 No blitz intake! Something else! Also just stick a sc on it. Nobody will notice. Share this post Link to post Share on other sites
Quball 60 Report post Posted October 10, 2014 Hmmm kinda makes me want one lol Share this post Link to post Share on other sites
will300 812 Report post Posted October 10, 2014 Cant register it untill monday What you actually mean is waiting until Lauren's not there, so she can't destroy it. Its a shame Toyota didn't release this kit earlier Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 10, 2014 Oi, Will! I don't think you can really talk can you? I've got a fair few more pics, as it arrived. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 10, 2014 Okay a few quick pics taken on my phone this morning when it arrived unexpectedly: This is the Aero Kit model which is basically the top spec GT86 apart from the limited edition Gialla which should be arriving soon too. The interior features a new design fascia panel: Full leather, this is an option though it is featured on GT86's from 2013 on: 18x17.5 OZ Ultralights shod with Yoko Advan V105 92Y (lower load rating) tyres: Outside the workshop at RRG Macc' with my car (lights on) on the ramps: A new button has arrived! This is for the tyre pressure sensors but I'm not quite sure how it works: 1 Quball reacted to this Share this post Link to post Share on other sites
Pitman 188 Report post Posted October 10, 2014 No blitz intake! Something else! Also just stick a sc on it. Nobody will notice. Why would he want to fit a S/C when he can fit a T/C? Very nice car, Rich 1 rob275 reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 10, 2014 Why would he want to fit a S/C when he can fit a T/C? Very nice car, Rich Because it is superiorcin every way shape or form 1 Pitman reacted to this Share this post Link to post Share on other sites
Pitman 188 Report post Posted October 10, 2014 Because it is superiorcin every way shape or form Ah, thank you for clearing that up . Off to find a dictionary to see what superiorcin means 2 rob275 and griffinnn reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 10, 2014 It's more superior than superior... I'd also like to know what it is as it's in my phones dictionary.. Lol 1 Pitman reacted to this Share this post Link to post Share on other sites
Riceburner 284 Report post Posted October 16, 2014 Back in the saddle 6 Pitman, Keethos, nikndel and 3 others reacted to this Share this post Link to post Share on other sites
