Booboo 11 Report post Posted March 26, 2021 My battery on my MY17 BRZ has finally given up. and as I understand most folks uprate the battery when replacing is it to a 60ah or 65ah? Sadly neither the RAC chap who came out to assist me or my local Halfords have any compatable ones to offer me. Due to the reversed terminals I suspect🙄 Where have owners found the best place to purchase a quality replacement? Share this post Link to post Share on other sites
Leeky 84 Report post Posted March 26, 2021 Im using a SuperBatt 072 80ah 650cca You can find them on ebay for £65 and they are pretty much the most powerful battery you can find that fits in the standard 86 battery tray. https://www.ebay.co.uk/itm/SB-072-031-069-Heavy-Duty-Car-Van-SUV-Battery-TOYOTA-LANDROVER-MITSUBISHI-/193262633319?_trksid=p2349624.m46890.l49292 1 Booboo reacted to this Share this post Link to post Share on other sites
BRZ-123 174 Report post Posted March 26, 2021 The above by@Leeky seems the best deal. Otherwise you can go to tayna.co.uk and the 2 big brand choices I can suggest are Yuasa YBX3031, 3000, 72Ah, 630A , 18.4 Kg, dimensions 26.0*17.4*22.5 (£74.97 delivered)Varta 70Ah, 630A, E24DIN570 413 063 , dimension 26.1 cm * 17.5 * 22 ( to top of terminal) (£65.89)The prices may not be accurate as i noted it a while ago. Sent from my SM-G781B using Tapatalk 2 Booboo and Joolz reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted March 26, 2021 Yuasa YBX3014 60Ah is what I bought to replace the feeble Panasonic in my 2017 BRZ. 2 Joolz and Booboo reacted to this Share this post Link to post Share on other sites
Booboo 11 Report post Posted March 27, 2021 Thank you guys Share this post Link to post Share on other sites
will300 812 Report post Posted March 29, 2021 I'm also running a Yuasa YBX3014. Although it's still not perfect and I've had to jump the car a couple of times during lockdown. However my battery is probably 3 or 4 years old now. I'll be making the switch to Lithium when the current one dies, although they are expensive. Share this post Link to post Share on other sites
Booboo 11 Report post Posted March 30, 2021 Thanks guys Halfords did recommend the Yuasa YBX3014 60Ah but don’t stock it After a bit of digging, I ended up getting a Bosch S4025 from Tayna as it was discounted Share this post Link to post Share on other sites
McDude 40 Report post Posted March 30, 2021 Bosch batteries are good. I do recommend a battery conditioner/charger if you aren't using it much during lockdown and/or short trips only. I've got a CTEK conditioner which has recovered my battery and kept me going the past year. It comes with nice little tails so you can integrate it with your vehicle wiring so you end up with a nice little connector plug under the bonnet which makes it super easy to use. Share this post Link to post Share on other sites
MartinT 514 Report post Posted March 30, 2021 I'll second the CTEK recommendation, it's very good for restoring battery performance. Fitting the connector to the battery makes charging very easy. Share this post Link to post Share on other sites
DuncanM 9 Report post Posted March 30, 2021 Hello, Just fitted one of these, great price and 4 year warranty. 70ah and fitted perfectly https://www.ebay.co.uk/itm/Varta-E24-Heavy-Duty-High-Performance-069-072-12V-70Ah-Car-Battery-4-Yr-Wnty/360530013877?pageci=775209d5-48c5-42fe-9aea-3583f6985b27 Also going to add a solar panel to ward off future parasitic draining. Share this post Link to post Share on other sites
Joolz 6 Report post Posted November 24, 2022 On 3/26/2021 at 10:56 PM, MartinT said: Yuasa YBX3014 60Ah is what I bought to replace the feeble Panasonic in my 2017 BRZ. Thanks so much for recommending this battery for my 2017 GT86, which I bought to replace my OEM larger 65ohm Toyota one that was at least 3-4 years old. Plus Toyota said had 61% health. Had the Yuasa about a month or two and volts also seem to read higher and car starts immediately. Love that it has roll over protection and a switch that flicks when it needs to be changed. Share this post Link to post Share on other sites
Joolz 6 Report post Posted November 24, 2022 On 3/26/2021 at 9:27 PM, BRZ-123 said: The above by@Leeky seems the best deal. Otherwise you can go to tayna.co.uk and the 2 big brand choices I can suggest are Yuasa YBX3031, 3000, 72Ah, 630A , 18.4 Kg, dimensions 26.0*17.4*22.5 (£74.97 delivered) Varta 70Ah, 630A, E24DIN570 413 063 , dimension 26.1 cm * 17.5 * 22 ( to top of terminal) (£65.89) The prices may not be accurate as i noted it a while ago. Sent from my SM-G781B using Tapatalk Thanks also for recommending these choices. Share this post Link to post Share on other sites
Subota Boy 402 Report post Posted November 25, 2022 I also have the Yuasa YBX 3014 fitted April 2019. Still going strong! Share this post Link to post Share on other sites
Joolz 6 Report post Posted December 1, 2022 On 11/25/2022 at 3:39 PM, Subota Boy said: I also have the Yuasa YBX 3014 fitted April 2019. Still going strong! Glad to hear yr Yuasa YBX 3014 Battery is still going strong a year later. Share this post Link to post Share on other sites
Subota Boy 402 Report post Posted December 2, 2022 On 12/1/2022 at 7:54 AM, Joolz said: Glad to hear yr Yuasa YBX 3014 Battery is still going strong a year later. Three plus years later Joolz 😉 Share this post Link to post Share on other sites
