Xyra 8 Report post Posted November 15, 2019 Hi All, After drooling after them for years, took the plunge on a rather nice 2013 GT86! Now onto a question, of course :) I want to get a space saver wheel for it, but not sure of the dimensions / tyre size to get. Would https://www.ebay.co.uk/itm/135-70-R16-Bridgestone-Subaru-5x100-Spacesaver-100M/123817698352?hash=item1cd41c2430:g:ASMAAOSw-hVdFb7e be likely to fit? I think its correct bolt spacing, but not sure on brake clearance, diameter etc... 3 GT86-Ian, Angelina and Badger reacted to this Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted November 15, 2019 Well the bolt holes are fine. Double-check my math, but the tyrewall height will be 94-ish mm, similar to the 97mm side wall 17" 215/45 standard fit, but it's a 16" radius, so it'll be smaller radius by about 10mm after the smaller tyre wall. I'd be very wary about putting that across the rear diff. There will be a 5% difference in circumference, and I reckon that's a lot of yaw... 1867mm circumference versus 1966mm (ignoring squash, which may be increase the problem on the space-saver). The primo in some markets does come with 16" wheels, but without offset, you're guessing if it will fit. Share this post Link to post Share on other sites
Badger 63 Report post Posted November 15, 2019 Also don't fit it to the rear axleSent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Angelina 82 Report post Posted November 15, 2019 Hi All, After drooling after them for years, took the plunge on a rather nice 2013 GT86! Now onto a question, of course I want to get a space saver wheel for it, but not sure of the dimensions / tyre size to get. Would https://www.ebay.co.uk/itm/135-70-R16-Bridgestone-Subaru-5x100-Spacesaver-100M/123817698352?hash=item1cd41c2430:g:ASMAAOSw-hVdFb7e be likely to fit? I think its correct bolt spacing, but not sure on brake clearance, diameter etc... Sent from my iPhone using Tapatalk this one. Share this post Link to post Share on other sites
Angelina 82 Report post Posted November 15, 2019 This one. Sorry about 2 pictures Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
vanko25 70 Report post Posted November 15, 2019 This one will fit over the front brakes. As Badger said if you have puncture at the back you will have to take a wheel of the front axle put it at the back and then fit the spare at the front. The diff won't like the different diameter wheel. Share this post Link to post Share on other sites
Xyra 8 Report post Posted November 15, 2019 Thank you so much! Forums are the best :) good point on rotating the tyres. I'll get onto one of those wheels. I hate being caught out without something (ever since the AA left me on the side of the M4 for over 4 hours with 2 kids under 4) so want to get something in place. Loving the car though. Finding the reverse quite high geared, got quite a lot of clutch smell getting into my driveway as it wanted to move quite quick (has a bit of a ramp), is this common? Share this post Link to post Share on other sites
nikndel 509 Report post Posted November 16, 2019 Clutch smell isn't good just means your burning it out Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted November 16, 2019 I carry a full size spare wheel in the boot and bought the other floor cover you can get to accommodate this from Australia. 1 Angelina reacted to this Share this post Link to post Share on other sites
Xyra 8 Report post Posted November 16, 2019 11 hours ago, nikndel said: Clutch smell isn't good just means your burning it out Yeh, I've managed to find a different angle to get into the drive which allows me a bit more momentum to get over the ramp so doesn't need so much clutch slip to get in now! Share this post Link to post Share on other sites
Xyra 8 Report post Posted November 16, 2019 7 hours ago, Test Drives Unlimited said: I carry a full size spare wheel in the boot and bought the other floor cover you can get to accommodate this from Australia. I might look at that. I quite like space savers though because if I have a full size spare then I don't get around to getting it fixed, whereas if I have an ugly speed restricted space saver on the car it prompts me to sort it!! 2 Angelina and Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
nikndel 509 Report post Posted November 16, 2019 12 minutes ago, Xyra said: Yeh, I've managed to find a different angle to get into the drive which allows me a bit more momentum to get over the ramp so doesn't need so much clutch slip to get in now! I have the same problem if I can't go up at a angle it won't go up at all 😂 Share this post Link to post Share on other sites
ualverig 1 Report post Posted November 18, 2019 Congrats on your new ride! Share this post Link to post Share on other sites
KevinA 695 Report post Posted November 18, 2019 Welcome to the club, and enjoy the 86 Share this post Link to post Share on other sites
MartinT 514 Report post Posted November 18, 2019 Just carry a can of Tyre Weld for emergencies? Share this post Link to post Share on other sites
Xyra 8 Report post Posted November 18, 2019 2 hours ago, MartinT said: Just carry a can of Tyre Weld for emergencies? I've had blowouts on more than one car, I'm paranoid I've never had a tyre die in a way it would have helped 6 hours ago, ualverig said: Congrats on your new ride! Thank you 2 hours ago, KevinA said: Welcome to the club, and enjoy the 86 Thank you 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Xyra 8 Report post Posted November 18, 2019 On 11/15/2019 at 6:48 PM, Angelina said: This one. Sorry about 2 pictures Sent from my iPhone using Tapatalk Thank you, I've found one of those and ordered it now. Much appreciated. Graham 1 Angelina reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 18, 2019 On 11/16/2019 at 7:18 PM, nikndel said: I have the same problem if I can't go up at a angle it won't go up at all 😂 Me too and the main reason why i can't lower mine at all. Share this post Link to post Share on other sites
