Gigrilla 1 Report post Posted July 3, 2017 Please can anyone offer any technical advice into this? My brand new GT86 is veering towards the right when it is pointing straight and you're accelerating. My brother-in-law also owns a GT86, and when he drives mine the same thing happens. When you're pulling off or accelerating along the road the car feels as though all the power is going to the back left wheel, and it veers off to the right, so you have to steer left to go forward in a straight line, and when you take your foot off the power it veers back to the left. The tracking has been tested and is perfect, and the tyres have been tested and proved to be faultless. The car is not delivering the power to the road through the wheels in the same way as my previous two GT86 or my brother-in-law's GT86 or the Demo GT86 from the dealer. It accelerates less quickly. On bumpy roads the car feels like something is loose, and has noise and feedback through the steering wheel. I received my car brand new with this issue, and the the Dealer claims this is a normal characteristic of the GT86. Has anyone else experienced this with their GT86? I have never experienced this problem before, with any vehicle I have owned or driven. What can possibly be wrong? I am so confused! Share this post Link to post Share on other sites
rob275 1817 Report post Posted July 3, 2017 I could be wrong but i'm sure someone had a similar issue and it was the steering angle sensor or something along them lines. Hopefully someone with a bigger brain capacity than me can chime in because i have the memory of a goldfish. Welcome to the club Share this post Link to post Share on other sites
Church 209 Report post Posted July 3, 2017 Weering off on accel/decel in straight line on dry tarmac isn't characteristic trait. I'd check most probable things: 1) tire pressure all around, if all is good & even - you already checked i guess 2) car alignment. probably at good suspension shop .. somehow dealership sounds a bit .. shady. Then maybe also what rob275 had suggested. IIRC it was VSC sensor recalibration. Though if anything, i'd blame 1. (with one tire half-flat it behaved exactly like that on power/power off) or 2. I'd check also that maybe something wrong with LSD .. but most probably not, after all you get weering off even with accel off. Not sure how to interpret on bumpy roads car feeling loose and that steering noise/fedback. Twins have rather bad noise insulation in general and steering feedback .. is good thing? And loose .. a bit more specific, how? But so far again, i'd check suspension parts state & alignment. If loose - not too stable / too twitchy steering, might be some toe-out that shouldn't be. Similar reason if loose - unstable under power. Slight toe-in in rear (at front i have 0 toe) made my car noticeably more stable in straights / when bad grip / under accel. In general, stock alignment has rather broad ranges of what passes as acceptable, while resulting in rather different handling at extremes of those ranges. Car brand new / not delivering power? Isn't it still break-in time? I got mine slightly used with 5K miles on clock, so don't know how it should be if completely new. If car's battery has been disconnected for whatever maintenance reasons, for some mileage it also might be a bit dull due until ecu learns fuel trims and accelerator pedal movement range. You can google for dead pedal fix & how to learn fuel trims sooner. Stock alignment for FR-S was: Front: Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less) Caster (Reference): 5°54' (5.90°) Steering Axis Inclination (Reference): 15°31' (15.52°) Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°) Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.) Rear: Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less) Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°) Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.) There is BIG difference between even slight toe-out vs toe-in in handling. If you always drive on public streets only, i'd get zero toe front, slight toe-in rear, camber .. by my tastes i'd wish for more camber front vs stock even on DD only, but if extra understeer doesn't put you off, stock camber values of 0 front, -1.12 rear should do. Advisable to have them even on both sides of course. By my tastes i'd wish by 0.5 more negative camber in front then in rear, so with stock rear camber it would be 1.5-1.6 negative camber front. Probably doable even with one set of camberbolts. If occasionally visiting track, then get more camber, or tire outsides will soon rip/wear off long before tire central part/inside will. For this i'd get camberbolts in both strut holes for total camber of ~ -2.2 front, and some cheap adjustable LCA for rear (whiteline / spc / eibach) in same fashion by 0.5 less, eg. -1.7. If visiting track often enough for most track wear to happen there and wishing to maximize grip, i'd get -3 to -3.2 camber front (and again by -.5 less at rear). Unfortunately for this one also needs camberplates, maxedout camber by bolt/-s alone won't suffice. Which unfortunately means also extra NVH. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted July 4, 2017 Get them to check the alignment I would say. Get a print out of it, maybe. This is the most likely cause. The only other thing could be a damaged balljoint or track rod end which has play so allowing the geommetry to move under acceleration. That or a worn or damaged bushing. Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted July 4, 2017 I test-drove one with odd tyres on the rear and it yawed a few degrees under power. One was a primacy, the other a Toyo of some description. It's quite sensitive to rear traction, but your problem could be in any of the wheel arches. Either way, your dealer has something to fix and should ruddy well get on with it. I'd be worried that they pranged it on delivery and and did a shoddy repair to save money. Whenever I hear the phrase "That's normal" from a car dealer I know they're lying. Share this post Link to post Share on other sites
Church 209 Report post Posted July 4, 2017 don't miss this bit. "when you take your foot off the power it veers back to the left" .. though: Gigrilla: this veering back - is it from steering changes to compensate trajectory changes under acceleration prior, or is this just going straight line w/o touching steering, when rolling in neutral or clutch-disengaged? And .. maybe it's dealer's job to fix, but i'd check/get printout at independent suspension shop alignment. Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 22 hours ago, rob275 said: I could be wrong but i'm sure someone had a similar issue and it was the steering angle sensor or something along them lines. Hopefully someone with a bigger brain capacity than me can chime in because i have the memory of a goldfish. Welcome to the club Thanks Rob. It feels more mechanical failure than electrical gremlins. Here's a video of my brother-in-law driving my car: https://drive.google.com/open?id=0B_s5QZrTMCLCdTQ1VEs4cEdEVUU Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 20 hours ago, Church said: Weering off on accel/decel in straight line on dry tarmac isn't characteristic trait. I'd check most probable things: 1) tire pressure all around, if all is good & even - you already checked i guess 2) car alignment. probably at good suspension shop .. somehow dealership sounds a bit .. shady. Then maybe also what rob275 had suggested. IIRC it was VSC sensor recalibration. Though if anything, i'd blame 1. (with one tire half-flat it behaved exactly like that on power/power off) or 2. I'd check also that maybe something wrong with LSD .. but most probably not, after all you get weering off even with accel off. Not sure how to interpret on bumpy roads car feeling loose and that steering noise/fedback. Twins have rather bad noise insulation in general and steering feedback .. is good thing? And loose .. a bit more specific, how? But so far again, i'd check suspension parts state & alignment. If loose - not too stable / too twitchy steering, might be some toe-out that shouldn't be. Similar reason if loose - unstable under power. Slight toe-in in rear (at front i have 0 toe) made my car noticeably more stable in straights / when bad grip / under accel. In general, stock alignment has rather broad ranges of what passes as acceptable, while resulting in rather different handling at extremes of those ranges. Car brand new / not delivering power? Isn't it still break-in time? I got mine slightly used with 5K miles on clock, so don't know how it should be if completely new. If car's battery has been disconnected for whatever maintenance reasons, for some mileage it also might be a bit dull due until ecu learns fuel trims and accelerator pedal movement range. You can google for dead pedal fix & how to learn fuel trims sooner. Stock alignment for FR-S was: Front: Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less) Caster (Reference): 5°54' (5.90°) Steering Axis Inclination (Reference): 15°31' (15.52°) Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°) Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.) Rear: Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less) Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°) Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.) There is BIG difference between even slight toe-out vs toe-in in handling. If you always drive on public streets only, i'd get zero toe front, slight toe-in rear, camber .. by my tastes i'd wish for more camber front vs stock even on DD only, but if extra understeer doesn't put you off, stock camber values of 0 front, -1.12 rear should do. Advisable to have them even on both sides of course. By my tastes i'd wish by 0.5 more negative camber in front then in rear, so with stock rear camber it would be 1.5-1.6 negative camber front. Probably doable even with one set of camberbolts. If occasionally visiting track, then get more camber, or tire outsides will soon rip/wear off long before tire central part/inside will. For this i'd get camberbolts in both strut holes for total camber of ~ -2.2 front, and some cheap adjustable LCA for rear (whiteline / spc / eibach) in same fashion by 0.5 less, eg. -1.7. If visiting track often enough for most track wear to happen there and wishing to maximize grip, i'd get -3 to -3.2 camber front (and again by -.5 less at rear). Unfortunately for this one also needs camberplates, maxedout camber by bolt/-s alone won't suffice. Which unfortunately means also extra NVH. Tracking has been tested and confirmed okay when stationary (see attached); the car goes straight when cruising, but not accelerating. I have attached a few other documents proving that I am not making it up either, which the Derby Toyota Dealer won't accept as a real fault. Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 7 hours ago, Church said: don't miss this bit. "when you take your foot off the power it veers back to the left" .. though: Gigrilla: this veering back - is it from steering changes to compensate trajectory changes under acceleration prior, or is this just going straight line w/o touching steering, when rolling in neutral or clutch-disengaged? And .. maybe it's dealer's job to fix, but i'd check/get printout at independent suspension shop alignment. When cruising you can take your hands off the wheel - it maintains its line, except when applying the throttle, or taking your foot off it. It is where it is correcting itself; when you accelerate, it veers, and you must keep the steering wheel turned slightly left to travel straight; when you remove your foot it then veers to the left, as you are holding the steering wheel to the left so you must then correct it to the right/straight again - this happens with each and every speeding up and reducing speed on the journey, to varying degrees. In city/town traffic, not so noticeable, but on the main roads it is soooo frustrating. The Inchcape Derby Dealership say it is normal to do this, but my previous two didn't do it, nor did their Demo GT86! Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 14 hours ago, Lauren said: Get them to check the alignment I would say. Get a print out of it, maybe. This is the most likely cause. The only other thing could be a damaged balljoint or track rod end which has play so allowing the geommetry to move under acceleration. That or a worn or damaged bushing. When Colchester Toyota had it on their ramp, we had a look and it seemed as though everything was okay, and everything was attached to the car properly; what none of us considered standing around the car puzzled, was that the suspension and wheels are attached to the subframe; I wonder if it is the subframe moving under acceleration? That was not tested then, or subsequently by Derby Toyota or the RAC report. Difficult to test perhaps, but my best deduction. Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 11 hours ago, nerdstrike said: I test-drove one with odd tyres on the rear and it yawed a few degrees under power. One was a primacy, the other a Toyo of some description. It's quite sensitive to rear traction, but your problem could be in any of the wheel arches. Either way, your dealer has something to fix and should ruddy well get on with it. I'd be worried that they pranged it on delivery and and did a shoddy repair to save money. Whenever I hear the phrase "That's normal" from a car dealer I know they're lying. The car was brand new when they delivered it, and had the problem when it arrived. The Dealer in Derby doesn't want to accept that this is not normal. All tyres have been independently tested, and the tracking is perfect. I have been putting up with this for over 5000 miles now! Share this post Link to post Share on other sites
Rich196 103 Report post Posted July 4, 2017 So process of elimination. Your tyres are good. Your alignment is good. All these elements are measured static.... The only static thing that hasn't been "checked" is that the brakes aren't dragging. (I doubt that its this though) Does it do with if you brake firmly in either direction? My personal train of though would be to check in order of simplicity: Does the traction control have any effect on this when turned completely off? You can try a "pedal dance" to completely turn it off. Google it. Subframe mounting, firstly are they tight? secondly are the bushes all in order. Is this causing the subframe to move under the car this would cause the symptoms you describe. If all this is "good" I would be looking at the diff and the drive shafts. Is the diff working correctly and within tolerance from left to right wheel. Is there any more backlash in one wheel then the other? Are all the wheel bearings okay? Good luck! Share this post Link to post Share on other sites
Keethos 842 Report post Posted July 4, 2017 I've attended a couple of CAT Driver Training courses and an activity that I have performed a couple of times now is high speed braking and threshold braking (holding the brake pedal on the limit just before the ABS kicks in) and the instructor get's you to do it without holding the steering wheel, believe me, the car should stop straight, no veering at all. Also, the car is RWD, there's no torque steer when accelerating (if that's what the dealer believes should be normal) so either tell the Derby dealer to learn more about the car and investigate in more depth, or travel further afield to RRG in Macclesfield and let someone who know's what they're doing check out the car (my local dealer turned down my bass to fix a rattle that I asked them to look into, I now travel 2 hours each way to RRG for any service, MOT, warranty work and the odd mod here and there too. Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 12 minutes ago, Rich196 said: So process of elimination. Your tyres are good. Your alignment is good. All these elements are measured static.... The only static thing that hasn't been "checked" is that the brakes aren't dragging. (I doubt that its this though) Does it do with if you brake firmly in either direction? My personal train of though would be to check in order of simplicity: Does the traction control have any effect on this when turned completely off? You can try a "pedal dance" to completely turn it off. Google it. Subframe mounting, firstly are they tight? secondly are the bushes all in order. Is this causing the subframe to move under the car this would cause the symptoms you describe. If all this is "good" I would be looking at the diff and the drive shafts. Is the diff working correctly and within tolerance from left to right wheel. Is there any more backlash in one wheel then the other? Are all the wheel bearings okay? Good luck! No-one wants to take the parts off to actually test the subframe; even the RAC report states it wasn't even lifted on a ramp, nothing was removed, and only things in plain sight were assessed. Toyota Colchester had it on their ramp, and everything seemed okay, but at the time we didn't think subframe! :-\ Colchester did however confirm the fault, even though it couldn't be diagnosed. Toyota Derby (supplying Dealer) are claiming nothing is wrong, and that it is normal and there is nothing to fix, even though I have the Colchester Toyota Report and the RAC Report stating the car veers to the right slightly under acceleration. Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 4 minutes ago, Keethos said: I've attended a couple of CAT Driver Training courses and an activity that I have performed a couple of times now is high speed braking and threshold braking (holding the brake pedal on the limit just before the ABS kicks in) and the instructor get's you to do it without holding the steering wheel, believe me, the car should stop straight, no veering at all. Also, the car is RWD, there's no torque steer when accelerating (if that's what the dealer believes should be normal) so either tell the Derby dealer to learn more about the car and investigate in more depth, or travel further afield to RRG in Macclesfield and let someone who know's what they're doing check out the car (my local dealer turned down my bass to fix a rattle that I asked them to look into, I now travel 2 hours each way to RRG for any service, MOT, warranty work and the odd mod here and there too. It brakes in a pretty straight line, although if you brake from accelerating position, you must correct steering wheel as it needs to be held to the left slightly to keep it going straight when accelerating, so it certainly keeps you on your toes! You can never relax in this car; how can the Derby Dealer say this is normal?? This is a video of my brother-in-law driving my car: https://drive.google.com/open?id=0B_s5QZrTMCLCdTQ1VEs4cEdEVUU - it is also slower to drive than his, and my previous ones, which he discusses in this different video: https://drive.google.com/open?id=0B_s5QZrTMCLCYlFFRUJHUGtoMWM :-( Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted July 4, 2017 16 minutes ago, Keethos said: I've attended a couple of CAT Driver Training courses and an activity that I have performed a couple of times now is high speed braking and threshold braking (holding the brake pedal on the limit just before the ABS kicks in) and the instructor get's you to do it without holding the steering wheel, believe me, the car should stop straight, no veering at all. Also, the car is RWD, there's no torque steer when accelerating (if that's what the dealer believes should be normal) so either tell the Derby dealer to learn more about the car and investigate in more depth, or travel further afield to RRG in Macclesfield and let someone who know's what they're doing check out the car (my local dealer turned down my bass to fix a rattle that I asked them to look into, I now travel 2 hours each way to RRG for any service, MOT, warranty work and the odd mod here and there too. I am stuck with Derby Toyota, Toyota Financial Service and Toyota themselves claiming nothing is wrong, so nothing to fix, so I cannot reject the car (although I did this after just 3 weeks of taking delivery). I have now done over 5000 miles... This is my latest complaint letter to them: COMPLAINT LETTER: Dear Sirs, I write to consolidate outstanding complaints and new ones into one overall complaint. I am a loyal Toyota customer, and because of my influence, my partner now owns her 2nd consecutive Toyota Yaris, my in-laws are about to buy their 2nd consecutive Toyota Auris Hybrid, my brother-in-law owns a GT86, my brother owns a Yaris, and others in my family were considering a Toyota for their next car until this happened. Do I really sound like the type of customer to be making this all up, just to create some (unnecessary) drama in my life? This is a series of 15 individual complaints, together constituting my overall complaint about my GT86 Pro, FE17 FHC, and the way I have been treated by Inchcape Toyota Derby, Toyota Financial Services and the Manufacturer, Toyota. (Supporting imagery and a few videos can be found via the link at the bottom of my email.) 1) NO SPOILER – The GT86 Pro was delivered without a Spoiler, despite it being a standard fitted part at point of sale, online and in Toyota Dealers at the time, with the option being to have a GT86 Pro without a spoiler fitted. The model below the Pro is the other way around, where you must order and pay more for a spoiler if you want one. Inchcape Toyota Derby delivered my brand-new GT86 Pro without a spoiler. They argued that the Insurance Company (new-for-old like-for-like insurance replacement after non-fault accident on 4th January) didn’t order one, but it is not necessary to order standard equipment. It took over 3 hours to get the dealer to agree – explicitly in an email – to collect the car at their own cost on a transporter (so no unnecessary miles were added to my car) and put it right, after they finally admitted on the phone that they had removed the spoiler as it wasn’t on the order form, even though it was standard equipment. In calls leading up to the delivery of the car I was assured it had a spoiler on it, as well as satellite navigation and mud-flaps. (This is unresolved, as per Complaint 11.) 2) STEERING FEEL & SUSPENSION NOISES AND LOOSE FEEL – When travelling over bumps in the road, the steering feels strange, and the suspension and steering column make noises, like something is loose on the car somewhere; this happens regardless of braking. This is intermittently experienced, as not all road surfaces are bumpy, but I do live in the middle of the countryside through several unavoidable B-lanes; none of my other cars experienced this, nor did the Demo GT86 from the Dealer. (This is unresolved, as per Complaint 5, 6, 7, 8, 9, 10.) 3) CAR VEERING TO THE RIGHT – When you accelerate, the car pulls off to the right-hand side, towards oncoming traffic. When you’re taking your foot off the accelerator from cruising, the car pulls off to the left. The tracking was tested as perfect, but somehow it feels like the back-left wheel is getting all the power under acceleration; the four tyres were also tested independently and found to be faultless; the tyre tread is the same on 3 of the four wheels (both the front Tyres, and the back-right Tyre) with 6mm treat, while the back-left Tyre has only got 5mm treat, showing that uneven wear is resulting from this issue. (This is unresolved, as per Complaint 5, 6, 7, 8, 9, 10.) 4) REFUSING TO ACCEPT REJECTION LETTER – Dealer – The Derby Dealer claims that I do not have the right to reject this car, as although I am the Registered Keeper, and the car is (until fully-paid by myself) owned by Toyota Financial Services, the car was paid for by my Insurance Policy, as part of a new-for-old like-for-like replacement scheme. 5) IGNORING THE CAR VEERING TO THE RIGHT – Dealer, TFS, TGB – Despite the Colchester Toyota Dealer and the RAC reports showing that the car veers off to the right when accelerating, the Derby Dealer and the Manufacturer claim this is a characteristic of the design of this car and perfectly normal and perfectly safe; this is not true. You cannot drive my car relaxed in any way, as any single second of lost concentration may result in an accident, with the car not travelling in the direction in which it is pointed. 6) NEW COMPLAINT: SELECTING A BIAST PARAGRAPH FOR CONCLUSION – The report from Toyota in Colchester is being ignored altogether. The first paragraph of the RAC Engineer’s Report is being used by the Derby Dealer and the Manufacturer and the Finance Company as their summary conclusion; this is only one paragraph of one part of multiple parts of this RAC Report and in-congruent with the rest of the report, which shows there are defects which may prove costly to repair. 7) MANUFACTURING FAULT – Not Fit for Purpose – This car was not designed to travel to the right when the steering wheel is pointing in a straight line, and the car is accelerating forward. The Wheel Alignment has been proved to be spot-on; it is not a tracking issue. The Tyres have been independently tested by the dealer and they are without fault. 8) SAFETY FAULT – Not Safe To Drive – This car is not my weekend car, it is my everyday car, so I am used to many more great miles behind the wheel in GT86 cars (x2 GT86 before FE17FHC, and x2 since this car) and enjoyed every single mile in them; this particular car is not built to the same standard and does not perform with the same precision or predictability; this car is difficult to maintain a straight line, difficult to guide around corners and stressful to drive – it is unsafe to veer off towards opposing traffic, and tiring to maintain a normal line of driving. 9) NEW COMPLAINT: FUTURE FAULTS – It is unclear what else could be affected by this problem, but I worry that undue pushing and/or pulling of the driveshaft to the rear-driven wheels from the front-mounted engine and gearbox will cause future problems with the drive-train, gearbox and engine itself; it is unclear what the current damage is or what future damage could result from non-repair and continued use. Toyota GB, Toyota Financial Services and the Dealer all claim nothing is wrong, despite the RAC report showing “Defects” that “should be considered” and “may cost lots of money”. 10) NEW COMPLAINT: CAR RETURNED UNFIXED – The car was sent to back to Toyota Derby after TFS suggested I took it to a more local Toyota Dealer to see if they could replicate the problem; Toyota Colchester were able to replicate the problem, but were unable to offer an explanation or diagnosis of the problem; they claimed it would need to be looked at over a long period of time with a trial-and-error approach, removing parts and replacing them until they found the problem; they were not happy taking the job on themselves, suggesting I took it back to the supplying Dealer, in Derby, to have them go through that process; they claimed that Toyota would be able to support the supplying Dealer financially, but that Toyota would probably not pay out on all the ramp time or for all of the parts that were replaced but found to be okay as part of the trial-and-error diagnosis process, and they may be left with parts that they cannot re-use, and they won’t be recompensed for. The original reasons for sending the car back to Toyota Derby were as follows: i. The spoiler had to be fitted after turning up without one. The Spoiler not being fitted at the factory worried me; I was concerned that the job of fitting one wasn’t easy, and concerned about the quality of fitting compared to a factory environment, worried it wasn’t going to be to the same standard, and raised my concerns with TFS, but was told this would be to the same exacting standard, performed by Toyota Trained Technicians to the same standard exactly as it would be in the factory, and not to worry. I was right to worry, as per Complaint Number 11. (This has NOT been fitted satisfactorily.) ii. The steering wheel doesn’t seem central to the seating position. (This still has NOT been repaired.) iii. The steering column makes noises going over bumps, as if something is loose. (This still has NOT been repaired.) iv. The car veers off to the right under acceleration, as if all the power is going to the back-left wheel instead of being spread across both rear wheels. When you take your foot off the accelerator the car then veers back to the left. This fault is present to varying degrees all the time; it is most noticeable when driving in a straight line from a steady speed as you press the accelerator pedal; it is also very noticeable in a straight line when you have cruise-control active and the car goes up and down a hill; it is forgivable not to notice this when driving around the town/city gently, but impossible to ignore when using main roads. (This still has NOT been repaired.) v. The central armrest hinge was broken when the car was delivered to me. (This has now been repaired.) The Derby Dealer has dealt with only one of the reasons the car was sent to them (armrest hinge), and despite the Colchester Dealer and the RAC Report confirming that the car is veering off to the right, I am being told by Toyota, TFS and the Derby Dealer that there is nothing wrong with my car and that it is a normal characteristic of the GT86 – something I know is not true, having driven several other GT86 cars covering more than 40,000 miles. The Dealer and Toyota are claiming there is no fault and therefore nothing to fix, despite the list of Defects listed by the RAC Report. The RAC report is not perfect but it clearly states the same problem that I originally reported, where they write “veering slightly to the right under acceleration”. It is also worth noting this report wrongfully ticks certain boxes that would claim certain parts are okay, where some boxes are ticked instead of having a ‘C’ denoting unchecked; the report makes it clear that the car was not tested on a ramp, nor was it lifted in any way, and no covers or parts were removed during the examination, making it clear in writing that this was a visual inspection and driving experience report; an example of this incongruent reporting is where there are ticks for the subframe checks, which cannot have been checked under these conditions, therefore the engineers report is not perfect when it comes to summarising the overall condition of the car - although it does state specific defects; the car has clear symptoms of undiagnosed issues. The car still makes noises over bumps and veers to the right under acceleration. The car was also sent back to me in a worse condition than it was sent to them for the repairs that have not happened. 11) NEW COMPLAINT: CAR SENT BACK WITH POORLY FITTED SPOILER, A MISSING PART & MY CAR DAMAGED – Dealer – Inchcape Toyota Derby returned my car to me with a poorly fitted spoiler and damage to my car; (a) it has gaps where it should appear flush with the body, and you can see the foam inside the mounting as well as the lines which should sit flush with the bodywork; (b) there is a missing part between the bodywork on the boot lid and the central spoiler support which should be there to protect the paintwork and is present on all other series 2 GT86 cars with a spoiler; (c) the boot lid now makes noises which it didn’t before, from within the boot lid when you lift or close it, I assume due to the metal shavings inside the boot lid from drilling during the installation; (d) there are scratches through the paint to the metal on the inside of my boot lid, surrounding the poorly fitted plastic plugs inserted to cover the mounting of the spoiler; (e) the plastic plugs used to fill the gaps where they have drilled through the metal are not the same as the ones fitted to other GT86 cars with a spoiler; (f) there are metal shavings all over the opening mechanism of the boot lid and inside the boot on the boot carpet; (g) Inchcape Toyota Derby refused to accept that the spoiler has been poorly fitted, with their General Manager, Chris Witham, stating that he personally checked the vehicle and the new spoiler before it left his dealership to come to me; he also stated that he expected me to have a problem with the installation as he thought I was disingenuous and he thought I was lying about it. After several phone-calls he agreed to look at the photos I had taken if I sent them to him, but that even if they showed I was not making it up he still wasn’t going to do anything about it, as he had already spent over £1500 fitting the spoiler in the first place; he also claimed that the spoiler was a good will gesture in the first place and he didn’t have to fit it, which is untrue. It is worth noting that I sourced a quote of £800 for the same work to be done by a more local Toyota Dealer, in-case the Derby Dealer wanted to pay them for the work to avoid collection and drop off issues. I did predict that this was the standard of work I should expect if I the Dealer fitted the spoiler instead of it being factory fitted, which was part of the rejection of my car, which was not accepted by the other parties as a reason to reject (although they accepted that if my other reasons were found to be true they would replace the car or repair it, and instead they are all now pretending noting is wrong). 12) NEW COMPLAINT: CAR RETURNED WITH BALL-POINT PEN INK ON STEERING WHEEL – Before the Delivery Driver returned the car to my possession I noticed some ink on the steering wheel which were not present when they took the car away to Derby. 13) NEW COMPLAINT: CAR RETURNED WITH REAR LEFT WIND DEFLECTOR, AT FRONT OF ARCH, BROKEN – Before the Delivery Driver returned the car to my possession I noticed that the back-left wheel arch’s front wind deflector was not in position, but floppy and hanging out of its position, also unable to be put back into position without it coming back out again, and again this was not an issue when they took the car away to Derby. 14) NEW COMPLAINT: TFS CHANGED MY DIRECT DEBIT TO COME OUT BEFORE I GET PAID AFTER I CHANGED IT TO BE AFTER I GET PAID WITHOUT NOTICE – Toyota Financial Services have changed the date of the Direct Debit coming out of my account. I changed the date of payment after it was set-up to be taken after I receive my monthly wages, to be taken after the 1st of the month, as my pay-dates vary at the end of each month; it has been taken before the end of the month by TFS for the past two payments; the first of these was taken on 30th May after the last correctly dated payment coming out on 2nd May – two payments in one month, but only one payday! I did not request this change of payment date, nor was I notified of the change. 15) NEW COMPLAINT: LESS QUICK THAN OTHER GT86s – My GT86, FE17 FHC, is not able to deliver as much power to the road and accelerate as quickly as other GT86 cars; I experience sluggish performance, and a higher consumption of petrol compared to my previous GT86’s, the Demo GT86 and my brother-in-law’s GT86, all of which accelerate quicker, respond quicker to the throttle throughout the rev range in all gears, and reach higher speeds in any given distance compared to FE17 FHC. I have attached a video of my brother-in-law’s experience in my car, comparing mine to his own GT86; initially he thought “it wasn’t that bad” and asked if I could “learn to live with it”, but he soon changed his tune, agreeing that something is seriously wrong with my car, after driving mine and his back-to-back. The spoiler, whilst avoidable, should have been the only issue I am left with now. From start to finish this has been an emotional roller-coaster and never-ending nightmare; I have suffered with stress, sleepless nights, and periods of unpaid work trying to sort this out during office hours when TFS, TGB and Toyota Dealer Management are available. This has been affecting my health so much that it has taken me several days to be able to find the mental strength necessary to write this email. I really have had enough. I am a human, who bought a GT86 in good faith, had it written off in a horrible accident, and is having nothing but problems with this brand-new replacement car, while being railroaded by the Dealer, Manufacturer and TFS. Please can you apply some common sense to this situation and replace this car for one that works properly, as it was designed to, with no defects, and a factory fitted spoiler. I am paying for one after all. Please do what is right for your customer, and provide me with a car commensurate with my investment, instead of leaving me in one that is only going to get worse; only wine gets better with age, not mechanical problems or manufacturing defects. Again, I am a loyal Toyota customer, and because of my influence, my partner now owns her 2nd consecutive Toyota Yaris, my in-laws are about to buy their 2nd consecutive Toyota Auris Hybrid, my brother-in-law owns a GT86, my brother owns a Yaris, and others in my family were considering a Toyota for their next car until this happened. Do I really sound like the type of customer to be making this all up, just to create some (unnecessary) drama in my life? Yours, NXXXX XXXXXX gXXXXXXX@hotmail.co.uk 079XXXXXXXX PHOTOS AND VIDEOS - Here is a link to photos of the Demo GT86 spoiler and hole-plugs inside its boot-lid, my GT86 spoiler, inside boot-lid scratches and different hole-plugs, steering wheel with ink on, back-left wheel arch wind deflector floppy, and three videos: https://drive.google.com/drive/folders/0B_s5QZrTMCLCSUFGNjJtWjRocEk?usp=sharing These videos contain my brother-in-law, James, who bought his GT86 on my advice, as I had one as a company car for over 30,000 miles; I was in a Yaris Hybrid when he bought his, but after a year I joined him in buying my 66 plate GT86 last September. These videos were taken this weekend in my insurance-replacement GT86 Pro, FE17 FHC. James has given me his permission to use this footage and happy to open dialogue with you to discuss his own experiences without having me around with a camera. 1 Keethos reacted to this Share this post Link to post Share on other sites
Church 209 Report post Posted July 4, 2017 1 hour ago, Gigrilla said: Tracking has been tested and confirmed okay when stationary (see attached); the car goes straight when cruising, but not accelerating. I have attached a few other documents proving that I am not making it up either, which the Derby Toyota Dealer won't accept as a real fault. Hmm, numbers look rather good to me, when i look at toe numbers / total thrust angle. But if anything, you may try to ask to get rear toe more even left to right. Even if as stock, camber front & rear is not adjustable (only minimal amount within undone/retightened mounting bolt play), but toe should be adjustable even stock, both front & rear. Still, existing alignment numbers imho shouldn't cause noticeable significant veering under accel, and that suggestion to even out toe-in in rear was more for perfectionism. Head scratching. Hmm, what else can be wrong on almost new car? :/ Can rear LSD somewhat misbehave and redirect more torque to just one wheel? My knowledge on that is not sufficient. Share this post Link to post Share on other sites
HariboPenguin 116 Report post Posted July 4, 2017 I think you are well within your rights to complain considering the amount of crap you seem to have gone through so far. I must admit when I was looking to buy mine I tried to book a test drive with Toyota Derby with the intention of probably buying, I was told that I'd have a callback which I never received and when I then chased them up and tried to arrange the test drive they just dismissed me and wouldn't take me seriously due to my age. Their own loss as I went elsewhere and purchased one later that week. I'd probably recommend you try what @Keethos suggested and take it up to @Riceburner at RRG Macclesfield, they are one of the most knowledgeable places in the UK when it comes to the 86 and are one of very few places that I'd let work on my car. I have a Toyota garage 20 mins away from me but would rather take the 1:30 hour trip to RRG as I know that they will look after me and do a good job without any fuss. 2 Gigrilla and Keethos reacted to this Share this post Link to post Share on other sites
Gigrilla 1 Report post Posted October 18, 2017 Please help. Toyota are still saying it is normal. I made this little video of it happening - does it happen to you when you're driving yours? Thanks. Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted October 18, 2017 If you rejected the car after 3 weeks why have you still got it. ?? Share this post Link to post Share on other sites
nikndel 509 Report post Posted October 19, 2017 I haven't read all this thread but if you are in Essex a few of us are at The Lion at Boreham on 29th about 1100 if you want other opinions as for getting anywhere with dealer or Toyota UK I'm not confident the good dealerships' are few and far between Share this post Link to post Share on other sites
Leeky 84 Report post Posted October 23, 2017 Now im not entirely sure on how the GT86’s Torsen LSD function when in the air... and you would have to be extremely careful in trying this... but if you were to jack up the car by the diff and run the car in gear I wonder if only one wheel turns... Because the symptoms you are having suggests to me a broken differential... because I had exactly the same issue after taking my MK2 Supra to Santapod and lunching my diff after too many full throttle launches. It would totally explain why your car pulls to one side under acceleration. Its essentially 1 wheel drive. A loose Subframe would knock, so I doubt its anything like mountings. Share this post Link to post Share on other sites
