Gringosteve 213 Report post Posted August 6, 2015 As you will not have a boost sensor would have to use calculated boost, not sure if it will work though on aftermarket forced induction Will be replacing battery with AFR values _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
Kodename47 446 Report post Posted August 6, 2015 As you will not have a boost sensor would have to use calculated boost, not sure if it will work though on aftermarket forced inductionWe have MAP sensors and James' is scaled to read his boost properly. 1 Gringosteve reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted August 6, 2015 Cool, it can read MAP _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 6, 2015 Thank you Steve I'd like to not stare at Citroen logos all day! What I will do is have a look and then give you the exact name, where do I buy the extended PID pack and how much is it? Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted August 6, 2015 You buy it via DashCommand app (press accounts button and purchase) and its $9.95. I am trying to buy it now but it won't connect to iTunes, not sure why _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 6, 2015 Hmm okay then, will attempt to do that this evening then. The full name of that dashboard is: Citroen Racing with NEW TRACK BUTTON. Let me know what you can do mate Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted August 6, 2015 As requested will upload tonight with a decent name _____________________________________ www.im-tuned.uk 1 JamesP1991 reacted to this Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 6, 2015 You are a star fella Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted August 6, 2015 I have managed to buy the Toyota additional parameters now. Works out at £7.99. I have changed the Citroen one. It is called "GT86 Racing" Future updates will be on my dedicated post. Sorry for thread crapping _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 10, 2015 Took my first couple of victims over the past week. A 12 plate Leon Cupra R was up my bum leading on to a dual carriageway near my house, 2nd gear pull from 30 upwards through to 4th and I pulled on him consistently. With my custom map boost is now building from 2800-3000 onwards easily now, it is so much better. Then the other day, a Revo tuned silver Octavia VRS on an 07 was taken off the lights up to 4th gear. Started off behind him, then as we hit the top of 2nd/start of 3rd I pulled out into the lane next to us and made inroads as we got into 4th.The guy driving and passenger pulled up alongside me at the next roundabout and asked why the thing went like shit off a shovel.. all I did was raise my eyebrows and I said... boost... and rolled the window up and they just laughed! Can't wait until the engine is forged and I can start pushing it further. Brakes and tyres are next though and will be done within the next 1-2 months. Saving hard at the moment 5 Keethos, Quball, Tareim and 2 others reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted August 10, 2015 Weapon 1 JamesP1991 reacted to this Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 11, 2015 Loving it Steve. Had an issue this morning though. When the overpipe is getting hot and flexing a bit, it appears to be rubbing on the steering column above the front subframe. The turbo manifold is obviously a bit different to my UEL I had on, and I think the slight positioning change has led to the overpipe sitting slightly differently. Fine when cold, but when hot and after being put through some load, I get quite a loud vibration/knocking coming through into the cabin and It gets worse as I turn the steering wheel. Checked the bash plate under the car and there is enough clearance underneath the turbo manifold, so it can't be rubbing against that, so it must be the overpipe. Mine is wrapped in titanium heat wrap too which makes it a little bit wider than the stock one, so I am guessing the tight fit has contributed to it. Doesn't pose any problem to the car, but is hugely annoying so will be getting it sorted ASAP. Share this post Link to post Share on other sites
Guest Report post Posted August 11, 2015 Perhaps a second pair of manifold gaskets would help? Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 11, 2015 Perhaps a second pair of manifold gaskets would help? Seen a couple of people at lunchtime today and they said I will have to change the overpipe to give me the room I need. Will probs go back to stock overpipe until I get a custom one made. It's the least effective part of the exhaust system any way. It appears under the heavier load now it is just flexing the pipe too much. Share this post Link to post Share on other sites
smudge 1020 Report post Posted August 11, 2015 Seen a couple of people at lunchtime today and they said I will have to change the overpipe to give me the room I need. Will probs go back to stock overpipe until I get a custom one made. It's the least effective part of the exhaust system any way. It appears under the heavier load now it is just flexing the pipe too much. Getting one custom made won't be easy. The twists and dimensions are very difficult to replicate which is why such a small piece is typically quite expensive from the brand names Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 11, 2015 I know, there is a slight wear mark on the steering column on the left hand side of the overpipe so it looks like I will just have to swap to the stock before Japfest 2. The stock one has a slight indent in it any way to allow for extra clearance. Might have to upgrade the engine mounts too perhaps to stop flex???????? Share this post Link to post Share on other sites
smudge 1020 Report post Posted August 11, 2015 I know, there is a slight wear mark on the steering column on the left hand side of the overpipe so it looks like I will just have to swap to the stock before Japfest 2. The stock one has a slight indent in it any way to allow for extra clearance. Might have to upgrade the engine mounts too perhaps to stop flex???????? Always a good mod anyway. I got the STi ones Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 11, 2015 Always a good mod anyway. I got the STi ones Did you just get the STI mounts off of Ebay mate? Might take a look tonight as the TRD ones seem quite expensive. Share this post Link to post Share on other sites
smudge 1020 Report post Posted August 11, 2015 Did you just get the STI mounts off of Ebay mate? Might take a look tonight as the TRD ones seem quite expensive. Got them off another member on the other forum 1 JamesP1991 reacted to this Share this post Link to post Share on other sites
Guest Report post Posted August 11, 2015 I bought Cusco mounts direct from Japan, very cheap. Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted August 11, 2015 Have you got a link for them Nige at all? If not I will investigate tonight Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted September 8, 2015 Turbo blanket for the 20G turbo will be on order next month, I am also contemplating upgrading the actuator and MAF pipe before I up the boost to 10 PSI at the start of next year and reach 300whp, but it is not necessary (just gives me more headroom for bigger numbers). However guys I need some advice. Now the power is all sorted, I need some help in regards to brakes and tyres. Seeing as I have near death experiences any time any precipitation falls on the road, I thought tyres and then brakes would be a good idea to do now, however fun it is. My initial thoughts were advan V105's, 225 section which should fit my 17x8's fairly nicely. However are 225's enough running a turbocharged setup? Any other tyres like Conti Sport 5's that are worth a mention? This will be a road car for the rest of the year with the aim of taking it on the track next year once it reaches a point that I am happy with it chassis/brakes/tyres wise. In regards to brakes, I was thinking just upgraded pads and new fluid for the time being, as I thought bigger discs would be kind of unnecessary on the road for the time being (can upgrade them later on next year before hitting the track). Does anyone have any feedback on this thought process, and what pads/fluid and possible discs to go for? I keep changing my mind and running only the stock brakes I have no reference point, so any feedback for those who have done the same I would really appreciate it. Cheers everyone. Share this post Link to post Share on other sites
rob275 1817 Report post Posted September 15, 2015 I'm using Dixcel Discs/Pads and Dunlop Sportmaxx RT's at the moment for rubber. Feel free to borrow my car to have a play in. 1 JamesP1991 reacted to this Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted September 17, 2015 Cheers dude, had a lot of advice from the FB thread so just ready to pull the trigger now Share this post Link to post Share on other sites
