adam_d 7 Report post Posted March 11, 2016 Hi everyone, My 15 plate GT86 has made the fuel pump chirp very loudly since I got it. I mentioned it when the car was in for a service at the end of January as I'd seen somewhere on here a definitive fix had been made available in November (can't find that thread). They came back and said it needed a new pump and it was fitted 3 weeks or so ago. It only ever seemed to make the noise when the temperature was above 6/7 degrees, and sure enough today the chirping is back as loudly as ever. As it's only a few weeks old, I'm not sure whether to go back or just live with it, what are the chances of it being fixed this time? It's also getting increasingly worse to get into 2nd gear, with 12000 miles on now I was hoping that would improve. The car has only had V Power in while I've had it. I should mention I'm a bit reluctant to go back to this dealer, as the dashcam I have in the car recorded a couple of things last time that didn't fill me with confidence (like spraying pressurised fuel all over the still hot engine, revving in neutral to show off behind the workshop). That might just be me being picky and I'm not sure I can do anything with the video anyway. I don't want to name the dealer as they have been good to me in the past with my last car. Would it be worth me getting the job done again? Any advice from anyone that knows the issue better greatly appreciated. Share this post Link to post Share on other sites
nikndel 509 Report post Posted March 11, 2016 I would be having a word with them Share this post Link to post Share on other sites
rob275 1817 Report post Posted March 11, 2016 The short and curlies is that there isn't a fix for this issue. There is supposedly a revised pump, but it comes back eventually. So as fat as that is concerned i'd say live with it, it doesn't affect the car in any way. The gear issue, theres a couple of fixes. GTB found one, i'll see if i can find the thread later. I had my lockout plate adjusted and transmission oil changed which made the world of difference. It hasn't fixed it completely, it still does it when cold going from 2nd to 1st but it's no big deal. the issue is when you're in the middle of your TSS runs and the f*cker won't go from 3rd to 2nd at woodbridge! Share this post Link to post Share on other sites
shiftspark 41 Report post Posted March 11, 2016 I have had a revised gear stick/linkage done under warranty and mine is fine now. Try messaging Riceburner at Macclesfield RRG who is very good with warranty issues. Share this post Link to post Share on other sites
adam_d 7 Report post Posted March 12, 2016 Thanks guys, I think I'll just stick with the chirp then instead of pushing any further. 22 hours ago, rob275 said: the issue is when you're in the middle of your TSS runs and the f*cker won't go from 3rd to 2nd at woodbridge! Aye that's a bit more of an issue than mine, I just look like a plank not being able to get 2nd at the end of my street on mornings. Gearbox oil change might be my first port of call I think. Share this post Link to post Share on other sites
long-gone 152 Report post Posted March 12, 2016 Dealer greased my linkage (ooer missus) and it's way better. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted March 13, 2016 The mtec springs, a heftier shifter knob and the whiteline positive shift bush make a big difference (but the whiteline bush does add a bit of nvh) Share this post Link to post Share on other sites
Lauren 2259 Report post Posted March 13, 2016 7 hours ago, adam_d said: Aye that's a bit more of an issue than mine, I just look like a plank not being able to get 2nd at the end of my street on mornings. Gearbox oil change might be my first port of call I think. I've always had the issues of changing down third to second at the end of my road, first thing in the morning. It's much the same if I stop and select first. I find I generally have to have a couple of attempts to get it in gear. But after that, it's fine. It tends to be a bit less of an issue when the temperatures warm a bit. But I think everyone pretty much has this. Whilst I get it's an annoyance every morning on the way to work for the once or twice it happens, I think all you can do is live with it. It's fine after all once it warms a little. 2 Foulsmell and adam_d reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted March 13, 2016 Mine is very stiff into first when cold, it's a case of full stop and give it a couple of tries usually. No problems with the other gears, and it's all fine when it warms up. Share this post Link to post Share on other sites
Guest BenGt86 Report post Posted August 18, 2016 At risk of reviving an old thread. Would an upgraded/aftermarket fuel pump sort the issue. Or would that only be used when going for Fi ? Share this post Link to post Share on other sites
DanJ 374 Report post Posted August 18, 2016 Its the high pressure direct injection pump that chirps, I'm pretty sure all the aftermarket upgrades are for the lower pressure supply pump so they won't exterminate the budgies! Share this post Link to post Share on other sites
Kodename47 446 Report post Posted August 19, 2016 12 hours ago, DanJ said: Its the high pressure direct injection pump that chirps, I'm pretty sure all the aftermarket upgrades are for the lower pressure supply pump so they won't exterminate the budgies! Correct Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted August 19, 2016 Muffle it with budgie smugglers? Share this post Link to post Share on other sites
