rob275 1817 Report post Posted October 27, 2016 @Ade Yes they are solid, admittedly on the box the picture shows bolted discs similar to the website. Perhaps they have changed design or it is indeed a bit of a development kit that I have. The calipers are alumimium indeed. Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 27, 2016 Welcome to the 362mm club! Shame red won't go with your blue wheels Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 27, 2016 15 minutes ago, smudge said: Welcome to the 362mm club! Shame red won't go with your blue wheels In the process of sourcing some new wheels anyway and they will be painted Nardo Grey and my stripe will be coming off. Seems silly to have the calipers a different colour when the anodised red on them is actually pretty nice Share this post Link to post Share on other sites
Ade 517 Report post Posted October 27, 2016 1 hour ago, rob275 said: @Ade Yes they are solid, admittedly on the box the picture shows bolted discs similar to the website. Perhaps they have changed design or it is indeed a bit of a development kit that I have. The calipers are alumimium indeed. I suspect its an STI brembo disc, dual drilled for 5x114 and 5x100. 51 minutes ago, smudge said: Welcome to the 362mm club! Shame red won't go with your blue wheels 326 not 362! these fit under 17" rims so dont worry you still have the biggest brakes of anyone Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 27, 2016 AFAIK Tarox make their own discs Share this post Link to post Share on other sites
Ade 517 Report post Posted October 27, 2016 50 minutes ago, rob275 said: AFAIK Tarox make their own discs Yeah sorry I meant a tarox Brembo sti spec disc. 326x30mm If that is the case its good because you have many disc options in the future. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted October 27, 2016 3 hours ago, smudge said: Welcome to the 362mm club! Welcome to the working car cl......Oh, wait..... 7 Tom B, Tareim, Mark-in-Stoke and 4 others reacted to this Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 27, 2016 5 hours ago, Ade said: I suspect its an STI brembo disc, dual drilled for 5x114 and 5x100. 326 not 362! these fit under 17" rims so dont worry you still have the biggest brakes of anyone Ah well, what a shame Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 27, 2016 3 hours ago, knightryder said: Welcome to the working car cl......Oh, wait..... *yawn* Share this post Link to post Share on other sites
Ade 517 Report post Posted October 27, 2016 8 minutes ago, smudge said: Ah well, what a shame Im going to buy some 3mm washers and 362mm discs when mine need replacing Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 27, 2016 10 minutes ago, Ade said: Im going to buy some 3mm washers and 362mm discs when mine need replacing 3mm washers? Share this post Link to post Share on other sites
Ade 517 Report post Posted October 27, 2016 10 minutes ago, Ade said: Im going to buy some 3mm washers and 362mm discs when mine need replacing 3mm washers? My discs are 356mm so I need to move my calipers out 3mm to fit a 362mm disc. Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 28, 2016 8 hours ago, Ade said: My discs are 356mm so I need to move my calipers out 3mm to fit a 362mm disc. Makes sense now I know the size of your discs! Share this post Link to post Share on other sites
Leosille 17 Report post Posted November 2, 2016 Give me a shout if you fancy having a go at fitting the brakes Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 3, 2016 Oddly bumped in to @maurice at Motorline Toyota Gatwick this morning whilst dropping the car in for it's 4th Service. @Leosille I think i'm going to try and do them next weekend if you're about. Share this post Link to post Share on other sites
Mike 458 Report post Posted November 3, 2016 Guessing Maurice was getting his coil packs sorted Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 3, 2016 indeed, told them about mine as well. I did forget to give Toyota a hks filter though so my service is only being half done Share this post Link to post Share on other sites
surrey86 352 Report post Posted November 3, 2016 Yeah. Having two 86's in at the same time with coilpack codes is good timing. Share this post Link to post Share on other sites
S18 RSG 429 Report post Posted November 3, 2016 My coilpack codes seem to always show up on a Friday, then clear by the Monday. Last time I went in they said "unless the code is there, we can't do the work". I think next time it's up I'm just gonna head straight there. Share this post Link to post Share on other sites
surrey86 352 Report post Posted November 3, 2016 I've not used Toyota software, but on my 2005 Bmw it stored every code with a mileage stamp forever. Even if the light has gone off I'm sure it surely must be stored in the history! Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 3, 2016 I can confirm they are stored regardless of whether the light is on or not. My P3 gauge displays it every time i turn the car on. Share this post Link to post Share on other sites
surrey86 352 Report post Posted November 3, 2016 I've the P3 aswell, but wasn't sure if it was recalling them. Just had the call, they aren't replacing them, just swapping them around. Basically a fob off Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 3, 2016 22 minutes ago, maurice said: I've the P3 aswell, but wasn't sure if it was recalling them. Just had the call, they aren't replacing them, just swapping them around. Basically a fob off They haven't even diagnosed my car today because it's remapped. Giving them a week then i'm calling the head office up to complain. Share this post Link to post Share on other sites
surrey86 352 Report post Posted November 3, 2016 Sounds like they had a productive day! That's just lazy. Pretty obvious if my car is putting out the same code on the gauge on start-up it's not related to a remap. I guess I'll be down there again after the next track day with another brace of codes. Share this post Link to post Share on other sites
Rich196 103 Report post Posted November 3, 2016 6 hours ago, maurice said: I've the P3 aswell, but wasn't sure if it was recalling them. Just had the call, they aren't replacing them, just swapping them around. Basically a fob off They mate be seeing if the code follows the pack or if it stays with the cylinder. Share this post Link to post Share on other sites
