nickfrog
Picking up Saturday
Yes, the subframe comes off separately, most likely to be that. But just my guess, do let us know what they find.
Probably not that cheap though by the looks of it!  :o
You'll need offset bushes to adjust the camber. I run 1.75 degrees negative on the rear and 2 on the front. Makes quite a difference. You will need camber bolts to adjust the front. I have coilovers with adjustable top mounts which makes it a doddle of course.
Also I have slightly reduced rear toe in. The car is much sharper to drive, makes it more lively as well.
There's basically no adjustment for camber really, unless you fit offset bushes at the rear or camber plates/coilovers on the front. You could easily dial in more understeer by having some toe in on the front and perhaps more toe in on the rear.
The car will react more sharply. That is it will turn in more positively. You may notice that the transition to oversteer will be quicker but that is more dependent upon having a better turn in. It won't affect traction per se.
225 isn't great on a 7" rim, the rim isn't wide enough. 225's will make it boring IMO, I ran 225s all this year for sprinting. Tons of grip, not much fun really. I should add that most will prefer more grip it's only me that is slightly deranged. ;)
For 225's keep the 45 profile. As for insurance, well you may want to check.
