Guest zen Report post Posted May 14, 2014 Driving home tonight, moderately twisty, undulating, tree-lined road... with the lights set to auto. I have to apologise to the driver in front of me (should they happen to read this) for apparently flashing them. It seems that the sensor is very sensitive, and the intermittent shade caused by dips and trees pals havoc with the lights. Now the lights are off/on. The sensitivity of these can be adjusted, but has anyone experience of doing this? Does it help? What did you set it to? Any other thoughts? Z PS: 800 miles still to go... Damn this work thing getting in the way of enjoyment! Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 14, 2014 I assume you are referring to bumps imitating you flashing the car in front as opposed to you actually flashing them. It's pretty common with HID lights because they are so bright. They have auto levellers in them but they don't work over bumps obviously lol. Share this post Link to post Share on other sites
Mike 458 Report post Posted May 14, 2014 I thought he meant the auto lights switching on and off? I've found them to be pretty sensitive to come on, then refuse to switch off automatically unless it gets a lot brighter yet if you turn them off and put back on auto they won't come back on Share this post Link to post Share on other sites
CHOSENMAN007 81 Report post Posted May 14, 2014 I never put mine on auto. On or off. Simple Lol.. 1 nikndel reacted to this Share this post Link to post Share on other sites
Fusion 13 Report post Posted May 14, 2014 I thought he meant the auto lights switching on and off? I've found them to be pretty sensitive to come on, then refuse to switch off automatically unless it gets a lot brighter yet if you turn them off and put back on auto they won't come back on Yeah, this pretty much sums up my experience... Share this post Link to post Share on other sites
Guest zen Report post Posted May 14, 2014 What Mike and Fusion said... Not a huge deal, but dammit the car has automatic headlights - they should work! And yes, on/off is what I will do in the meantime, I just wondered if anyone had success getting the sensitivity adjusted? Share this post Link to post Share on other sites
Keethos 842 Report post Posted May 14, 2014 I wouldn't worry Zen, it won't seem like you're flashing the person in front as the when the lights do come on, even when your back out in bright light, there is a delay before they turn off again which I assume is to prevent them from blowing when you continuously driver through flickers sunlight due to trees and what not so as a result, doesn't make it seem like your flashing anyone. The sensitivity can be adjusted but they need to be taken to a dealer to do as I believe they have to plug into the car to tweak the setting on a computer or something. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted May 14, 2014 The sensitivity can be adjusted but they need to be taken to a dealer to do as I believe they have to plug into the car to tweak the setting on a computer or something.You can get Techstream from eBay or from torrent sites, however you need a cable (Tactrix) which is the expensive part. Alternatively Toyota should do it for free anyway. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted May 15, 2014 I serioiusly wouldn't worry about it. They do come on, quickly but they take a while to turn off as others have said. So it will never look like you're flashing the driver in front and they'll just think, 'oh they've got auto headlights'. You can adjust the sensitivity but i would just drive around a while longer yet, you'll get used to it. Share this post Link to post Share on other sites
Qu1ckn1ck 44 Report post Posted May 15, 2014 I switched my auto headlights off as soon as I got the car - Simples. Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted May 15, 2014 I got my Lights on Auto,so as soon as I push the button to start the car they come on Automatically all the time - [ I used to have a Saab ] I don't like the Day Running Lights fitted as standard,as the rear lights aren't on either Share this post Link to post Share on other sites
