Tom B 44 Report post Posted October 24, 2016 Hi Guys, Ever since buying my GT I've never liked the feel of the clutch. I'm getting horrible clunky shifts between 1st and 2nd and when dropping down from 3rd - 2nd or 2nd - 1st it can feel like I'm mushing the gears together rather than a slick engagement. There are also issue when sat in traffic, I depress the clutch, mush my way into 1st then I get an awful 'Clunk' that sort of shudders to the back axel. Not nice at all. It doesn't happen every time however. Its bothering me more and more now, so just been outside trying to gather some more info, and noticed a sort of whining noise, that disappears when the clutch is pressed (see poor quality video.) Anyone else experienced anything thing like this? I'm worried it may be something serious. Car is a 62 plate but only 18k on the clock. Thanks in advance. Share this post Link to post Share on other sites
rob275 1817 Report post Posted October 24, 2016 Most of the cars have this issue to one extent or another, i've learnt to live with it for 4 years thus it can't be that serious. Share this post Link to post Share on other sites
Keethos 842 Report post Posted October 24, 2016 You'll feel a lil clunk when engaging first when stationary from the diff which is normal I believe, recently I've been feeling that 1st from stationary can a be a lil stubborn but if you double clutch it it slots in fine. Not too sure what I'm hearing though from the video. Share this post Link to post Share on other sites
Tom B 44 Report post Posted October 24, 2016 Thanks for the replies guys, Maybe it is something I'm going to have to get use to! Keith - There's sort of a whirling noise when in neutral and clutch up, disappears when clutch is pressed. It may well be normal too, just not something I've noticed/experienced before. 20k service coming soon I'll mention it then to get a second opinion. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 24, 2016 I can't tell from your video, the clonking noise, I've no idea. But if it's just a bit of whirring when the clutch is up, it's likely to be the release bearing. Nothing to worry about really if that's what it is. Share this post Link to post Share on other sites
Church 209 Report post Posted October 24, 2016 Single clunk when from stationary engaging in gear, most probably is diff loading as Keethos said. During first drives it seemed weird due not seeing such in other cars driven, but now i don't notice it, too used to it. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted October 24, 2016 Ah the clunk. Will be the input shaft on the gearbox. Mine has done it for the last 90K+ miles. Some clutch adjustment may help. Share this post Link to post Share on other sites
Tom B 44 Report post Posted October 24, 2016 Reassuring to know it's quite common then, I'll have to suck it up and get use to it I suppose Share this post Link to post Share on other sites
shiftspark 41 Report post Posted October 24, 2016 Yeah mine does it occasionally esp on colder mornings when engaging 1st gear from 1st start up. Fine after that. Share this post Link to post Share on other sites
Church 209 Report post Posted October 25, 2016 Funny, that some of mechanical noises don't seem annoying at all, rather on contrary, make feeling more involved/immersed. I will not go for forced induction nor i will buy very expensive sequential gearboxes, but always loved turbo whistling/supercharger and straight cut gear whines/tire squeel when on grip limit. It may annoy in long cruising travels, but otherwise make feel like being in rally car. Share this post Link to post Share on other sites
Mike 458 Report post Posted October 25, 2016 16 hours ago, Lauren said: I can't tell from your video, the clonking noise, I've no idea. But if it's just a bit of whirring when the clutch is up, it's likely to be the release bearing. Nothing to worry about really if that's what it is. Thought the release bearing would make a noise when the clutch is down? Like mine is currently doing for a short time... Share this post Link to post Share on other sites
smudge 1020 Report post Posted October 25, 2016 It's a "characteristic" of the car 2 Riceburner and Tom B reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted October 25, 2016 Mine does this too. Put it in neutral with the clutch up and you get a whirring/grinding from the gearbox. I think there's a free spinning shaft in the gearbox rattling, when you press the clutch it stops spinning. Its alway done it but made worse by the white line insert. 1 Tom B reacted to this Share this post Link to post Share on other sites
