Red One
A Flash On The Dash!
Apologies if there is an answer to this somewhere but if there is - I can't find it.
I have a light within the rev counter that has started flashing constantly whenever the ignition is switched off. And it never used to!
The one showing a car and padlock. I guess something to do with the security of the vehicle. There is an audible bleep alternate with the flashing icon.
I have read that it may be something to do with the battery in the key fob. I replaced the battery in both fobs about 6 weeks ago and the key icon is green when ignition is on, not yellow.
Light starts flashing as soon as the engine is turned off together with bleeping. I can get out of the car, lock it with the key fob but the light continues to flash. Returned to car 12+ hours later and light is still flashing. But it never used to! How can I stop it flashing?
Anyone any ideas?  😷
Hmm, my first idea was fob battery, but you told you already replaced it less then two months ago. Hmm, to what position your lights are switched to?
I have the lights set to 'auto'. I have turned them to 'off' to see if that makes any difference but it doesn't.
What i will say is that i sat in the car when checking the lights and closed the door. That solved one problem. The bleeping stopped!(idiot!).    So reference to my original post - the bleeping is not an issue.
Starts as sweet as anything but as soon as the ignition is switched off that light starts flashing. And it never used to. 🤬😷
Hi Lauren
I know I have sat in the car previously with no ignition on and there has been no lights flashing. Which begs the question - is it possible to dis-arm the immobiliser so that the flashing would stop? If so then that is obviously the mode the car has been in up to now.
7 hours ago, Red One said:
Hi Lauren
It's supposed to do it, so that thieves can see it's got an immobiliser. Mines always done it. It will do it after a time out after the ignition is turned off. I am pretty sure you would invalidate your insurance if you disarmed the immoboliser, it is there there to prevent your car being stolen. Not sure why you would worry about a flashing light. There is another  by the boot release for the alarm.
It shouldn't bleep at you, unless you have a door open. Maybe look up the alarm codes for the keypad?
Toyota/Subaru love their beeps: ignition on while door is open, key battery low, engaging reverse sensors, seat belt not on in occupied seat... I'm sure there's more I haven't heard yet!
Not withstanding the annoying "I'm not going to lock until you wiggle my bonnet-closed sensor" beep beep beep. At least it doesn't beep near the redline like the RX8 did...
