Test Drives Unlimited 278 Report post Posted June 13, 2015 I would like a Reverse Camera Kit from Fensport but as am not DIY minded I would like it fitted please How much do you charge to fit this item ? Share this post Link to post Share on other sites
Lauren 2259 Report post Posted June 13, 2015 You may do better to email Fensport, Nigel. Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted June 13, 2015 OK thanks Lauren Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted June 16, 2015 Now have one of these on order Sent from my Archos 53 Platinum using Tapatalk Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted July 30, 2015 Well I would like to thank Fensport for fitting my New Reversing Camera yesterday This was the first time that they had ever fitted such a Kit to the GT86/BRZ and now that they know how to fit such a Kit,they will be offering this service to other Customers A couple of Photos Post below : 1 Keethos reacted to this Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 30, 2015 How much did they charge? Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted July 30, 2015 They charged me £100 (£50p/hr) to fit but it took a lot longer than 2hrs work so I think they will charge a lot more than that in the future !! My car was the guina pig Share this post Link to post Share on other sites
smudge 1020 Report post Posted July 30, 2015 Could swear they've done one before... Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted July 30, 2015 No this was the first time Jordan,as they weren't sure what to charge me for the fitting ! Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 31, 2015 Just as a reference, Jay charged me £25 (plus some costs) n took around 40 mins! Maybe they could hire him as a contractor? Lol Share this post Link to post Share on other sites
ABs_GT 6 Report post Posted January 4, 2017 Install links and images for Fensport Rear View Camera Kit I've been looking for ages for easy install instructions as my Fensport Kit didn't come with any and everyone online seems to have a different kit with and without harnesses. So here are a few links to videos I used when installing mine. Not all of every video is relevant, but at least all the links are in one place here. 1. Check Head Unit receives signal when reverse is engaged. Both my brother's and my cars had this already working. Follow this video to access the service menu of the HU. In "General" (I think - have a play - you'll find it) you'll see reverse as "No". Engage reverse (engine doesn't have to be on) and this will change to yes. GREAT!! If this doesn't happen for you, two of the videos below show how to add one wire to inform the HU when reverse is engaged. Ok so the video doesnt show English headings, but it's essentially the 'navigation volume'...also I think it's more the rate of taps and not the actual number...not sure...but it's easy enough to access. 2. HU removal and plugging harness into HU - note these videos show tapping etc but the Fensport kit didn't any The video above I found really useful as he installs the exact same camera harness as Fensport into a set up with SatNav, so if you've already got Sat Nav OEM fitted, it's a useful heads up. 3.Video and PDF guide of principles of wiring through boot/trim & cutting hole for camera http://carboncarsystems.com.au/files/gt86-reverse-cam.pdf 3 Squadrone Rosso, Philip and Keethos reacted to this Share this post Link to post Share on other sites
Squadrone Rosso 82 Report post Posted January 5, 2017 Super helpful. Thanks. As I understood it, these kits are no longer available?? Share this post Link to post Share on other sites
Steeps 294 Report post Posted January 5, 2017 I've still got mine from the original group buy sitting on a shelf... should probably fit it soon. Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted January 5, 2017 I had mine fitted by Fensport Sent from my ASUS_A001 using Tapatalk Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted January 5, 2017 Just a word of warning I had my Camera relocated to the Center of the Trim as it wasn't picking up everything when reversing !! Sent from my ASUS_A001 using Tapatalk Share this post Link to post Share on other sites
Squadrone Rosso 82 Report post Posted January 6, 2017 @Fensport, will you be making any more kits available? Thanks, Simon Share this post Link to post Share on other sites
ABs_GT 6 Report post Posted January 6, 2017 I had mine on the shelf from quite a few months ago so when wiring the Valenti bumper light all went to pot I thought I'd do the camera. few points - especially if fensport see the thread... 1. the hole drill bit is too small by about 2mm. Nothing a litttle file couldn't sort. Don't hesitate to be bloody forceful getting the camera into the drilled hole. 2. My HU had the 'camera' socket already plugged with an adaptor with one red wire going to pin 3. The camera adapter supplied had a wire in pin 3 anyway amoungst a few more lol. So we just swapped them out anyway and all was fine. Adapters were bloody stiff to remove too...not exactly as easy as the vids suggested 3. The cable FROM the HU is massive so you have loads of rooms for manoeuvre. We routed mine down he passenger silk trim, around the rear speaker and into the boot. 4. Cable FROM camera is TOO SHORT to go from the the boot lid and through the rubber housing into to boot cavity itself. This is a bit bad. I tried pulling the cable from the HU into the boot, but getting it through the rubber wasn't gonna happen. Instead I taped the connection and hid it behind the grommit. Share this post Link to post Share on other sites
Brig 10 Report post Posted January 25, 2017 Just received camera ordered at weekend Dan at fensport told me the website hadn't been updated so was showing item out of stock and to just go ahead and place order and it will go through Cheers for promt service 2 Fensport and Squadrone Rosso reacted to this Share this post Link to post Share on other sites
willclarke 50 Report post Posted August 26, 2018 On 06/01/2017 at 9:44 AM, ABs_GT said: I had mine on the shelf from quite a few months ago so when wiring the Valenti bumper light all went to pot I thought I'd do the camera. few points - especially if fensport see the thread... 1. the hole drill bit is too small by about 2mm. Nothing a litttle file couldn't sort. Don't hesitate to be bloody forceful getting the camera into the drilled hole. 2. My HU had the 'camera' socket already plugged with an adaptor with one red wire going to pin 3. The camera adapter supplied had a wire in pin 3 anyway amoungst a few more lol. So we just swapped them out anyway and all was fine. Adapters were bloody stiff to remove too...not exactly as easy as the vids suggested 3. The cable FROM the HU is massive so you have loads of rooms for manoeuvre. We routed mine down he passenger silk trim, around the rear speaker and into the boot. 4. Cable FROM camera is TOO SHORT to go from the the boot lid and through the rubber housing into to boot cavity itself. This is a bit bad. I tried pulling the cable from the HU into the boot, but getting it through the rubber wasn't gonna happen. Instead I taped the connection and hid it behind the grommit. I'm just about to order one of these myself - Fensport advised it was 3 hours labour at £50+VAT (therefore £180 fitting) Think this is a bit steep personally so will try install myself - hoping i don't need to be very electrically minded for this?? also, is point 4 been sorted on more recent kits anybody? Share this post Link to post Share on other sites
Gawen 0 Report post Posted March 2, 2020 When you bought the camera how much was it.? Did it fit above number plate near boot handle? Share this post Link to post Share on other sites
