rob275 1817 Report post Posted April 24, 2015 They will fit fine, but nobody is running that offset. As people have said, 35 is common, 33 isn't far off. Share this post Link to post Share on other sites
Ade 517 Report post Posted April 24, 2015 Just my two cents on rim choice: Moving away from the stock et48 will affect the relationship between scrub radius and tyre centre patch. Moving out (lower offset for more poke) will make the car understeer a bit more. Adding camber to the front pushes the scrub radius out slightly. Off the top of my head I think if you have 1.5 degree of camber you need to reduce wheel offset by 8mm to keep the same relationship between scrub raduis and tyre centre patch. Share this post Link to post Share on other sites
Tareim 343 Report post Posted April 24, 2015 Just my two cents on rim choice: Moving away from the stock et48 will affect the relationship between scrub radius and tyre centre patch. Moving out (lower offset for more poke) will make the car understeer a bit more. Adding camber to the front pushes the scrub radius out slightly. Off the top of my head I think if you have 1.5 degree of camber you need to reduce wheel offset by 8mm to keep the same relationship between scrub raduis and tyre centre patch. what's scrub radius? never come across that term before Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 Just my two cents on rim choice: Moving away from the stock et48 will affect the relationship between scrub radius and tyre centre patch. Moving out (lower offset for more poke) will make the car understeer a bit more. Adding camber to the front pushes the scrub radius out slightly. Off the top of my head I think if you have 1.5 degree of camber you need to reduce wheel offset by 8mm to keep the same relationship between scrub raduis and tyre centre patch. Interesting point, but for 95% of the people that change their wheels they won't be bothered about this Share this post Link to post Share on other sites
Ade 517 Report post Posted April 24, 2015 That is true smudge, but rather than assume they are not bothered, I just want to make it clear sometihng is being compromised by messing with the wheel offsets. Tareim: http://en.wikipedia.org/wiki/Scrub_radius Share this post Link to post Share on other sites
Deacon 1357 Report post Posted April 24, 2015 Again, most people won't be bothered but it also puts more strain on the suspension when lowering the offset of the wheels and increasing the width. Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 But let's not forget, more poke and camber looks awesome too 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 24, 2015 Thanks for the advice, I have made an offer on the wheels, so let's see what happens. Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 Tell us! Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 Ooooh I think I know what they are Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted April 24, 2015 I have an idea as well after a search for the size... Probably way way off though 1 Tweedbean reacted to this Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 I have an idea as well after a search for the size... Probably way way off though eBay works wonders eh Jamie 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Mark-in-Stoke 488 Report post Posted April 24, 2015 The et33 makes it an easier wheel to look up, my god we're a nosey bunch of git's aren't we. 2 Omer86 and Tweedbean reacted to this Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 And it's not something you usually see on a GT86 Me thinks it's something usually suited to Ze Germans 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 24, 2015 Ha it is a very rare size to be fair. Don't think they guy is going to accept the offer so the search continues. Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 24, 2015 And it's not something you usually see on a GT86 Me thinks it's something usually suited to Ze Germans Yeah I got similar comments when putting Volks CE28's on my Mini clubby, Japanese wheels on a German/British car. I'm all for something different. Share this post Link to post Share on other sites
smudge 1020 Report post Posted April 24, 2015 Good on ya mate 1 Tweedbean reacted to this Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted April 25, 2015 Different is what will make the car unique after all mate 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 25, 2015 Just to check that the centre bore on a GT86 is 56.1mm isnt it? Share this post Link to post Share on other sites
rob275 1817 Report post Posted April 25, 2015 Just to check that the centre bore on a GT86 is 56.1mm isnt it? yes 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 30, 2015 Quick question does anyone know if you can fit 4x 18x8 wheels and 4x 225 40 18 tyres in the back of the 86? Can the wheelsthen fit in the back once tyres are on?I have the tyres and wheels being delivered to me then I need to get them to a tyre place to get them fitted, then the wheels back to mine ready to fit once coilovers are on. Share this post Link to post Share on other sites
rob275 1817 Report post Posted April 30, 2015 Yes, if you stack them they should just fit. It will be tight though. 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted April 30, 2015 Will the wheels with tyres on fit in with out stacking? Share this post Link to post Share on other sites
rob275 1817 Report post Posted April 30, 2015 You will need to stack atleast one on top so get something to protect the faces like a towel 1 Tweedbean reacted to this Share this post Link to post Share on other sites
remal 85 Report post Posted May 18, 2015 Ok save me starting a new thread I searched and found this to ask a few questions After meeting a few of your at Japfest last weekend the wife wants alloys. Only taken me 6 months and after seeing all the other 86's with lovely alloys she said we need some. Great A few questions. What do I need to know when buying new wheels for the 86 if I go for the standard 17" x 7". Offset etc.. 17x7 et48 for the edit Also what I need to do if I go 18" x 8" offset. Share this post Link to post Share on other sites
