Twigman 93 Report post Posted May 22, 2014 Does anyone do half placing on number plate digits? If you find anyone can you let me know? Share this post Link to post Share on other sites
toyokid 27 Report post Posted June 5, 2014 Popped to Fensport on Monday and did an Ecutek a little disappointed with poor Tesco fuel quality! Observations so far, 8 mpg improvement on low performance map! Based on 100 odd miles on way back home, when touring with car full of luggage This was on a steady cruise on A15 in a rural area, needed to change down to 5th on hills, but not many in Lincolnshire 2nd map 3.5 mpg improvement when having a steady traffic laden drive to Oulton Park, on track today, so I am sure that will changeThe car had a baseline 36.1mpg Share this post Link to post Share on other sites
Lauren 2259 Report post Posted June 5, 2014 It's nice to hear that you are getting reasonable mpg. I will get a remap at some point, but I don't think I will be flicking through maps, so I'm intersted in how your mpg is affected when in the performance map. What about how it goes like though? Did you map it on Tesco Momentum? Adrian reckons that Shell is the way to go for maximum advance. I use little else, I admit. Nice day for a track day. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted June 5, 2014 It's nice to hear that you are getting reasonable mpg. I will get a remap at some point, but I don't think I will be flicking through maps, so I'm intersted in how your mpg is affected when in the performance map. What about how it goes like though? Did you map it on Tesco Momentum? Adrian reckons that Shell is the way to go for maximum advance. I use little else, I admit.The stock map does run very rich, I'm guessing for safety due to the high compression. Even the performance maps should be more efficient than the stock map. Especially when you can reduce/remove the fuel trims as obviously this has a big effect on how the car runs.This is the OEM map:I've highlighted the area that you naturally hit when going full throttle. Low 11/High 10 is rich by any standard, my car doesn't even go into 10s now. Decent tuning should always benefit in both instances once you start tying the systems in together. I managed a good average of 39mpg on my run up to Cosworth last week.And yes, Shell VP is the way to go. Seems to have better knock resistance and helps keep the engine cleaner by all accounts. Share this post Link to post Share on other sites
toyokid 27 Report post Posted June 6, 2014 Well I am going to use Shell in the future! Even map 2 gives nigh on 40 mpg on 70 odd country cruise Does anyone know what components are changed at the various services? Share this post Link to post Share on other sites
CHOSENMAN007 81 Report post Posted June 6, 2014 Toyokid. Salute. Hks legamax is the bomb. Mine sounds better the more I drive it. Will get a de cat manifold and a supercharger installed in July as waiting on a kit. Will keep you posted on changes of sound. But on a n.a set up I think its up there on sound quality! Share this post Link to post Share on other sites
toyokid 27 Report post Posted June 10, 2014 At the Yorkshire Modified Car meet at Pickering on Sunday Jamie was parked next to me with his custom made single exit exhaust and we did the obligatory noise comparison with a focus group of about 10 everyone said our cars sounded very different but not better or worse and apparently the noise level was not so different! I find that hard to believe when I have 3 silencers v Jamie's 1 StephenTorque is definitely up since the remap Was a bit sleepy at 6.00am on the road for the YMC meet and when near my destination I thought, how few gear changes I had made up steep hills Car a lot less noisy on startup since altering the ignition retard Stephen Share this post Link to post Share on other sites
CHOSENMAN007 81 Report post Posted June 10, 2014 You should postva video.. I'm curious to see how different yours sounds to mine as we are the only 2 guys with the Hks legs Max premium. Share this post Link to post Share on other sites
toyokid 27 Report post Posted June 19, 2014 I have seen a Samco induction tube (standard air box) fitted to some cars, which has enables the noise generator to be deleted, which looks much neater and less complicated. Any thoughts on noticeable noise levels? I don't suppose there is a performance benefit? Stephen Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted June 19, 2014 Haven't noticed any difference in induction noise with mine fitted other than the loss of the drone, but it did get done at the same time as the exhaust... I just wanted rid of the sound generator as just didn't think it sounded right Share this post Link to post Share on other sites
toyokid 27 Report post Posted July 13, 2014 Popped down to Lechlade Circa 200 odd miles each way Hot so using aircon Running on economy map 1 Mainly constant throttle No great acceleration Seems to change the character of the car, more relaxing to drive And averaging 40 mpg! Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
toyokid 27 Report post Posted July 17, 2014 Just driven 700 odd miles on my jollies, so switched to economy map Mainly constant throttle using c. Control and pottering Achieving 40 mpg using A/C most of the time The car felt much more docile which was pleasant for touring. Decided to switch to map 3 when back home Throttle was much crisper, much more linear to input Much more performance and fun to drive Economy in everyday use 35 mpg So very good But.....that extra performance is based on leaner fuelling and more advance So have been aware on more pinking at roundabouts etc when not giving her beans! Kinda reminds me of one of my old Celicas before getting rid 340bhp Recaros 40mm Bilsteins all corner weighted When everything was working in harmony, she was brilliant and a real adrenalin rush The 86 gives me the same adrenalin rush, pretty much out of the box With everyday reliability and unbelievable economy When I do eventually get my 350-400bhp Carlos Sainz Celica back on the road, the worry will be an anti-climax! Hey ho Sent from my iPad using Tapatalk 1 Keethos reacted to this Share this post Link to post Share on other sites
Special K 442 Report post Posted July 17, 2014 Steve, Sounds like map 3 needs 'tweaking'... there is no reason for pinking on a trailing throttle... ... unless you've been going for crap fuel, of course.... Don't wanna sell your CS Celica, do you..? Spec K Share this post Link to post Share on other sites
toyokid 27 Report post Posted July 18, 2014 Thanks for the offer Keith But I have owned my Carlos Sainz for 12 years and can't sell her! Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
toyokid 27 Report post Posted July 18, 2014 Hi Keith You have got me curious For those that have Ecutek tunes, which map do you use for daily driving? Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
