Ade 517 Report post Posted May 10, 2017 I've been meaning to post some pic of my audio install. Rather than write an essay I will be brief with lots of pictures. Aim of the system was light and competition level sound quality. I used CLD, Egg box foam and 3M thinsulate to sound deaden. The latter two are very very light. I added 6kg of CLD total. I decided pretty quickly to have a front and sub with a fully active setup. Pioneer Headunit with DSP and crossovers built in and 3 amplifiers; a two channel for tweeters, a two channel for mid/bass and a single channel for sub. The two front amps fit under the drivers and passenger seat. The sub amp goes in the back mounted to the sub box on isolation feet. Doors were damped with CLD, sealed to make air tight as possible and foamed to prevent rattles. Speakers mounted on MDF baffles treated to seal them from water damage. I also added sound deadening to rear arches which made a world of difference. System Spec DEH-80PRS Headunit Genesis Profile 2 for Tweeters (under passenger seat) Genesis Profile 4 bridged to drive the mid/bass (Under Driver Seat) Genesis Profile Sub for the Sub (boot) Morel Virtus 602 component fronts Peerless XLS 10 4ohm subwoofer Van Damme Pro Audio Blue Speaker Cable (2.5mm for mid/bass and Sub, 1.5mm for tweeters) Van Damme Pro Audio Instrument cable with Brass Gold plated RCA connetors CCA 4AWG and 8AWG power cable Here is a ton of pictures. The headunit Dash in pieces fitting the Microphone for the bluetooth phone calls. Surround was glued together and covered Filled Next up - The Battery Installed an AGM battery for better voltage regulation The Doors Damped with CLD and added some Egg box foam inside Sealed to make as air tight as possible Whole door covered in closed cell foam Speaker baffle with acoustic foam to protect the back of the speaker from water behind the speaker Tweeter in the dash The Amps I forgot to take a pic of the passenger side but here is the drivers side for the mid bass (its bridged Genesis Profile 4) The Sub Sub enclosure is a hybrid MDF and Fiberglass molded to the base of the boot and bolted down using the spare wheel anchor and screwed to a bit of MDF glue the panel at the back. Sizing it up ready to fibreglass curing Made the top and test fitted the sub and Grill covered amp mounted on isolation supports installed in car Finally some addition sound deadening to block some road noise Layer of CLD to reduce panel resonance and two layer of 3M thinsulate This is the best place to start with sound deadening. Reduced road noise massively. So there it is. Hope you like it. Any questions please ask away. Cheers 7 Keethos, j@cko0Oo, Deacon and 4 others reacted to this Share this post Link to post Share on other sites
Varelco 211 Report post Posted May 10, 2017 Looks good Ade! now the weather has improved I will be doing similar. What material did you use to seal the doors? looks like some sort of corrugated plastic? Also are your front door speakers full range or have you set up filters? Share this post Link to post Share on other sites
Ade 517 Report post Posted May 10, 2017 Thanks! I used twin wall 6mm thick to seal the doors from the builder merchant. I covered it with CLD to dampen them. I used this rather than wood because 1) it doesn't mind water and 2) its light. Regarding crossovers, Its still work in progress but I currently have: Right tweeter is high pass filtered at 2.5khz and left at 3.15Khz both with 12dB/Octave slopes Mid bass are both low passed at 2Khz with 12dB/Octave slopes and High passed at 100Hz with 12dB/octave slope Sub is low passed at 80Hz with a 24dB/ocatave slope 1 j@cko0Oo reacted to this Share this post Link to post Share on other sites
TTR 509 Report post Posted May 10, 2017 You really don't do half measures 😂 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted May 10, 2017 11 minutes ago, TTR said: You really don't do half measures 😂 haha its true. 1 TTR reacted to this Share this post Link to post Share on other sites
DanJ 374 Report post Posted May 10, 2017 No wonder you've been quiet! Looks like a top job, look forward to hearing it :-) 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted May 10, 2017 No wonder you've been quiet! Looks like a top job, look forward to hearing it :-) Cheers Dan. Im still fine tuning it at the moment but getting there. Its taken since Jan to get the hardware install finished so I havent done any trackdays this year. Time to get on it... Share this post Link to post Share on other sites
DanJ 374 Report post Posted May 10, 2017 There's still time for Blyton at the end of May. I fancy going back to Snetterton in June or July with some brakes that work this time as well! Share this post Link to post Share on other sites
Deacon 1357 Report post Posted May 10, 2017 16 minutes ago, DanJ said: There's still time for Blyton at the end of May. I fancy going back to Snetterton in June or July with some brakes that work this time as well! You should definitely do Blyton @Ade should be a cracking day! 1 Ade reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted May 10, 2017 I must say, a lovely job, with some really good attention to detail. Only thing I was going to ask is why a single din head unit? Share this post Link to post Share on other sites
AJ124 118 Report post Posted May 10, 2017 Nicely done @Ade dash panel came out well too. 1 Ade reacted to this Share this post Link to post Share on other sites
surrey86 352 Report post Posted May 10, 2017 Looks excellent, very well finished. Sounds weird, but having done this sort of thing before I most like the insides of the doors, very comprehensive. 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted May 10, 2017 I must say, a lovely job, with some really good attention to detail. Only thing I was going to ask is why a single din head unit? Thanks 😊 I went with single because there isnt a pure sound quality double din available on the market with a good dsp. It seems the sound quality headunit are still mostly single din whereas the doubles are more about fancy screens and features and less about all out sound quality. Sent from my SM-G935F using Tapatalk Share this post Link to post Share on other sites
Lauren 2259 Report post Posted May 11, 2017 Ah I see. Did you not consider a DSP such as an Audison Bit10 etc? It's what I've got in my four year old setup. 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 Ah I see. Did you not consider a DSP such as an Audison Bit10 etc? It's what I've got in my four year old setup. Yes I did but im not a fan of going digital to analogue then analogue back to digital then digital to analogue again that and the increased complexity of the system. Would have used a bit ten D if I could get a HU with digital out through. The pioneer does all the signal processing, crossovers ect in the digital domain at 48bits then has 3 very high quality DACs and analoge sections. Its an utter bargain for what it is. Sent from my SM-G935F using Tapatalk Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 10 hours ago, AJ124 said: Nicely done @Ade dash panel came out well too. Yeah not too bad. Had to add some think strips at the side to cover it properly but overall very happy Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 10 hours ago, maurice said: Looks excellent, very well finished. Sounds weird, but having done this sort of thing before I most like the insides of the doors, very comprehensive. I know what you mean as the door preparation has the biggest effect on the sound. Each door took me 6 hours and copies amounts of both vaseline and expletives to get the speaker cable through the door grommets. Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 He's some closer pictures of the speakers. I love the smooth sound of Morel drive units in my home hifi so I though I would give their Virtus 602s a try. and the XLS10 sub. XLS stands for extra long stroke, these little 10" monsters are capable of delivering pretty good high volume low distortion sound due to the high linear excursion. So you get the benefit of a tighter bottom end in a sealed box without sacrificing volume and ability to go low. Monstrous magnet Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 11, 2017 Looks great @Ade time well spent! I was going to do one for mine but took the totally lazy approach of OEM+ 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 Just now, rob275 said: Looks great @Ade time well spent! I was going to do one for mine but took the totally lazy approach of OEM+ Cheers - still lots of tuning to do but starting to sound decent. I very nearly went for OEM+ and many times during this install (which took since January) was I swearing at myself for going the full custom route. Share this post Link to post Share on other sites
Rich 378 Report post Posted May 11, 2017 15 hours ago, DanJ said: There's still time for Blyton at the end of May. I fancy going back to Snetterton in June or July with some brakes that work this time as well! I have a Javelin voucher to spend, could be tempted by Snett if it's a Javelin day (will try not to crash this time). 2 TTR and Ade reacted to this Share this post Link to post Share on other sites
TTR 509 Report post Posted May 11, 2017 Just now, Rich said: I have a Javelin voucher to spend, could be tempted by Snett if it's a Javelin day (will try not to crash this time). Or you could join me and some friends at Anglesey on July 12th 1 Rich reacted to this Share this post Link to post Share on other sites
DanJ 374 Report post Posted May 11, 2017 Just now, Rich said: I have a Javelin voucher to spend, could be tempted by Snett if it's a Javelin day (will try not to crash this time). Or you could join me and some friends at Anglesey on July 12th That's not a Javelin day though is it? Could do Snetterton in June and then Anglesey in July. Share this post Link to post Share on other sites
TTR 509 Report post Posted May 11, 2017 4 minutes ago, DanJ said: That's not a Javelin day though is it? Could do Snetterton in June and then Anglesey in July. You can indeed book it on Javelin http://www.javelintrackdays.co.uk/trackdays/index.php?route=product/product&path=65&product_id=503 Share this post Link to post Share on other sites
Ade 517 Report post Posted May 11, 2017 Oooo I like Snet. Javellin have one at Snet on 26th June http://www.javelintrackdays.co.uk/trackdays/index.php?route=product/product&path=75&product_id=360 or I could be tempted to do an evening session at snet on the 6th June. Can get off work at 3pm. http://www.javelintrackdays.co.uk/trackdays/index.php?route=product/product&path=75&product_id=365 Share this post Link to post Share on other sites
