Void3.0 0 Report post Posted December 31, 2018 Have an issue, found oil/fuild leak on top of my engine and don't know where it's come from or what could be leaking. Leak is on the passager side (left hand side) doesn't seem to be coming from timing cover or from near the head gasket so was wondering if anyone had any ideas or suggestions. Can anyone help? Any help would be mostly appreciated Thanks Joe Share this post Link to post Share on other sites
Lmc 27 Report post Posted December 31, 2018 Is it actually leaking or just a bit of residue left behind from the last oil change Share this post Link to post Share on other sites
Void3.0 0 Report post Posted December 31, 2018 It could be but my last oil change was in summer so it should have burnt off I would of thought, it was behind the air con pump Share this post Link to post Share on other sites
Lauren 2259 Report post Posted December 31, 2018 Oil will only burn off if it's put somewhere very hot like an exhaust manifold. Otherwise it will just sit there. Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted December 31, 2018 looks like it has been there for a while and there isn't much of it. Clean it up as best you can, check oil level and keep an eye on it. 99% sure you haven't a problem. Share this post Link to post Share on other sites
sam534 62 Report post Posted December 31, 2018 Squirt a bit of brake cleaner down there when the engine isn't warm, should evaporate offSent from my STF-L09 using Tapatalk Share this post Link to post Share on other sites
