Cerastes 204 Report post Posted September 24, 2017 Hi all on the lookout for front drop links to go with the flex A's. Thanks. Cheapest I could find was £35. Share this post Link to post Share on other sites
Foulsmell 120 Report post Posted September 24, 2017 Hi all on the lookout for front drop links to go with the flex A's. Thanks. Cheapest I could find was £35. Found them! Share this post Link to post Share on other sites
Cerastes 204 Report post Posted September 24, 2017 42 minutes ago, Foulsmell said: Found them! Huh? Share this post Link to post Share on other sites
Lauren 2259 Report post Posted September 24, 2017 You'll want adjustable drop links to shorten them a bit so the ARB is level. You can run stock drop links but they are fit once only for the most part, so it's better to go aftermarket. A bit more than £35 but not hugely expensive. Share this post Link to post Share on other sites
KevinA 695 Report post Posted September 24, 2017 The Flex A is shorter than the OEM suspension, hence needing adjustable drop links as @Lauren says. Share this post Link to post Share on other sites
Rich 378 Report post Posted September 25, 2017 I'd go aftermarket, you can pick some up for under £100 - not worth saving a bit of money now to have problems later. Share this post Link to post Share on other sites
