Willtl 54 Report post Posted March 23, 2017 For people with the stock tyres, are you all running at 35psi for road use? I would like to soften up the ride a bit and was wondering whether it would be safe to knock a few psi out of the tyres to see if that improves things for me. Share this post Link to post Share on other sites
vanko25 70 Report post Posted March 23, 2017 35 psi is the recommended pressure. Mine were at 32 before I pumped them up the other day and to be honest haven't felt any difference between 32 and 35. The other guys will tell if it is safe to go below that without putting uneven wear on the tyres. Share this post Link to post Share on other sites
CHOSENMAN007 81 Report post Posted March 23, 2017 29 psi all round. Share this post Link to post Share on other sites
tristanom 2 Report post Posted March 23, 2017 I would try 30psi. The chalk test is another method to know the perfect pressure your tires. Share this post Link to post Share on other sites
Steeps 294 Report post Posted March 23, 2017 I'm running 32, had them at 27 for a while after a track session and my pump had gone walkies. Didn't like it that low for road use. Share this post Link to post Share on other sites
ThatGuyThere 54 Report post Posted March 23, 2017 4 hours ago, tristanom said: I would try 30psi. The chalk test is another method to know the perfect pressure your tires. Go on... Share this post Link to post Share on other sites
Tareim 343 Report post Posted March 23, 2017 6 hours ago, tristanom said: I would try 30psi. The chalk test is another method to know the perfect pressure your tires. chalk test? Share this post Link to post Share on other sites
nerdstrike 186 Report post Posted March 23, 2017 Draw a line of chalk across the tyres, roll slowly over a flat surface, see where the chalk gets rubbed off to tell where the contact patch is. Over-inflation will leave chalk on the shoulders of the tyre with the middle bare. Under inflation will tend to rub the shoulders clean, but not the middle. Camber has an effect too, so you have to take that into account. It's a poor-man's wheel alignment test - far from perfect. Share this post Link to post Share on other sites
Rich 378 Report post Posted March 24, 2017 Another chalk test for track is to put a line around the sidewalls to see how much the tyre is rolling over on to them. 1 Ade reacted to this Share this post Link to post Share on other sites
remal 85 Report post Posted March 28, 2017 I've been running 32PSi for 2 years now and feel better. no issues with tyre wear but then again I dont do the miles. Only 8 k on mine from new. But going to add 2k to that in a week with another euro trip in June Share this post Link to post Share on other sites
