Squadrone Rosso 82 Report post Posted January 11, 2016 Hi. I have tried a search but couldn't find anything. Is this a common issue on the 86/BRZ? Now the temperature has dropped a little, coupled with the damp weather, all the interior glass is steamed up. Not running condensation & it clears in a few minutes of running the rear screen heater & front max setting. Car appears otherwise dry. No coolant usage, wet carpets or anything. Our other car is unaffected (Fiat Panda Cross). Any thoughts appreciated Cheers, Simon Share this post Link to post Share on other sites
Paul 442 Report post Posted January 11, 2016 You naughty boy. 1 Squadrone Rosso reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted January 11, 2016 It's going to sound stupid as f*ck, but it's because of the angle of the windows. It's normal, we all get it. Just a case of putting the A/C on for a few mins. 3 Rich, Squadrone Rosso and Deacon reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted January 11, 2016 Seriously, just run the AC all the time. It makes a negligible difference to fuel consumption and prevents this from happening. I have run mine constantly in all the 80,000 miles I've had the car. 1 remal reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted January 11, 2016 3 minutes ago, Lauren said: Seriously, just run the AC all the time. It makes a negligible difference to fuel consumption and prevents this from happening. I have run mine constantly in all the 80,000 miles I've had the car. It's also stops the AC seals drying out so you lose less coolant gas. Share this post Link to post Share on other sites
Keethos 842 Report post Posted January 11, 2016 Yeah, it's normal, though my rears are taking a lil longer to clear than I remember....mind you they need a proper clean and sealing to be fair. Share this post Link to post Share on other sites
Squadrone Rosso 82 Report post Posted January 11, 2016 We always leave the AC Climate Control. Never turn it off. Never in the recirc mode either. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted January 11, 2016 The reason is, I'm pretty sure is that the cabin area is so small and there is a lot of glass. Mine mists up all the time. If you get in the car slightly wet or simply if it's raining it will always do it. I often have to have a quick blast in demist mode if I've been in the car damp and everytime first thing in the morning in the winter if I'm leaving early. So yes, I'd say it's a common issue. 1 Squadrone Rosso reacted to this Share this post Link to post Share on other sites
Church 209 Report post Posted January 12, 2016 Some modes also automatically switch on AC and switch off recirc, if one has left auto on (wasn't it after 'thaw front window' button?). In winter i often 'fix' that manually after cold starts, for car to heat up sooner. See no need to defog with AC or use outside even colder air, when it's still minus temps inside and i'm still brushing snow & ice from car exterior. During normal drive .. yes, just as manual says, if windows are fogged, AC deals with that, and rather quickly (=colder air directed to windows prevents condensation on it even with humid air inside, so in few mins both front and side windows demist). I still don't drive with AC always on, finding that in fully heated up car after longer drive windows mostly don't need that if i have recirc off. It seems somewhat wrong in my mind to have heater & AC at same time, just like putting hot pot into fridge. Fog? - AC on. None? - off. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted January 12, 2016 Church, you can have hot air conditioned air as well as cold air conditioned air. The air conditioning dries out the air, that's why it's so good at demisting. So AC is not just for cooling. The temperature has been mild in the UK throughout December without any frosts and has been well above freezing. In the UK we have had the wettest December in many years, so it is more likely that the issue at the moment with the car constantly misting up is due to high humidity and the likelihood of introducing moisture into the car when people get in and out. It's far less of an issue when it hasn't been raining pretty much everyday for the last month which has pretty much been the case in the UK. Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted January 12, 2016 Please can someone test this for me today. Start the car and turn A/C off and Auto off (in that order) Set the temp to Lo Press auto Did your A/C light come on automatically? Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted January 12, 2016 Church, if you are local to Manchester or coming to JapFest I can fix that for you with my OBD tool. You can turn off auto a/c and auto a/c functions so that when you press front demist the a/c doesn't come on Share this post Link to post Share on other sites
Church 209 Report post Posted January 12, 2016 Gringosteve: no, i live & drive in Latvia :). Visiting here because this forum is in english (one of two foreign languages i know little bit alongside russian), because i was interested in one product originated here (Jay's set of backup camera), and because UK is in EU, hence lot of stuff like product availability, main shops, legal issues, shipping policies, pricing, warranty issues are more comon then eg. something over pond @US or down under @AU. Still, thanks for tips that it's configurable option. Will keep that in mind. Not bothered too much about it yet, once or twice a day pressing two buttons more is no biggie. 1 Squadrone Rosso reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted January 12, 2016 Ah no problem my Latvian friend, your English is perfect! Share this post Link to post Share on other sites
Rich 378 Report post Posted January 12, 2016 3 hours ago, Gringosteve said: Church, if you are local to Manchester or coming to JapFest I can fix that for you with my OBD tool. You can turn off auto a/c and auto a/c functions so that when you press front demist the a/c doesn't come on Can you adjust the timer on the courtesy light with that? Mine is set to 15s and that's way too short. Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted January 12, 2016 Yes you can! Have mine at 30 seconds at the moment Share this post Link to post Share on other sites
Rich 378 Report post Posted January 12, 2016 Nice, I'll have to come find you at JapFest (unless you're at Bedford?) Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted January 12, 2016 Won't be at Bedford but will be at JapFest on the club stand 1 Rich reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted January 12, 2016 I can sort it at Bedford for you if you can't wait. Assuming it's carista by the screenshots? I'm also a tester. 2 Gringosteve and Rich reacted to this Share this post Link to post Share on other sites
