charged
Nice upgrade for someone?
Mind you, if it's only the turbo location, presumably that bit could be modified... I'd always wondered about the compression - with what little I know about such things - the Saab Turbos always ran lower compression than the n/a cars. You couldn't simply bolt the turbo gubbins on...
How do the kits get around that - clever mapping?
3 hours ago, Tareim said:
the main advantage of the FA20 DIT Mike is that the compression has been lowered to about 10.6 so less chance of detonation I think
Most certainly yes, but with the costs involved to get it in and then running, then looking at upgrades for the turbo and so on, I think it'd work out a very expensive conversion :)
Indeed, mapping is accommodated in mind of it being a high compression engine with air being forced in. So long as its done carefully, it is reliable.
We've tried to break ours..... :lol:
You didn't try hard enough then, carry on :P
I believe the gearbox mounting is different too, so custom work required. Plus the bonus of having to get a custom manifold for the turbo and extra bits that needs too for the turbo. The DIT also hasn't got much headroom as the injectors aren't a simple swap.
Remember that DI does help with FI and having a high CR actually helps turbo spool.
