keelerad
Bonnet Struts
Well after a false start with some initial doubts about the fittings I have just fitted the bonnet struts that Fat Rab brought down with him that we got from Chris at Tarmac Sportz
Note to get mine to fit like in the pictures on the other forum I had to mix the fittings, so Drivers side I used the one labelled L on the bonnet and R on the wing (see photos), checked operation and clearance when closing and everything seems good.
Posted ImagePosted Image
Only tool you really need a 12mm ring spanner, though a ratcheting one helps to get to the bolts in the wings
Posted Image
Did do the double spanner trick with a standard spanner though to crack it loose
Posted Image
All done. look Ma no hands
Posted Image
Nice easy fit, only the 4 bolts to undo
Yep, I like 'em. Not sure they'd be useful for me - I usually get the stable boy to open the bonnet and put his head on the block to prevent it closing... ;)
Seems that Fensport have some in stock..
Spec K
2 hours ago, Minion said:
I've had a set of these on for near enough three years now, not had one single problem with them. Would certainly buy again!! :)
which version - Greddy/GrimmSpeed/Speedline??
