About Lewis Hashbrown
Warwick
Lewis Hashbrown changed their profile photo
Stanceparts air cups
Lewis Hashbrown replied to Lewis Hashbrown's topic in For Sale GT86 / BRZ Parts
They were great when I had them on. The main idea behind them is to have the performance of Coilovers but when you get to a bad road / bump you raise it up. 95% of the time you drive with them aired out so it's acting as a basic top mount. From what I read they're designed to be used to raise the car up for a little amount of time. Not to be driven while aired up all the time. It's either fully up or fully down as well -
Lewis Hashbrown started following Clutch feel / responsiveness, Stanceparts air cups, BC racing BR Series Coilovers and and 4 others
Stanceparts aircups (fit on bc Coilovers+others) £625 (grey airtank) Was on the car for around 2k miles https://www.stanceparts.com/product/complete-kit-front-rear/ Fronts are 20mm and the rears are 12.5mm shaft diameter https://imgur.com/a/yaNUrvj Ideally collection from Warwick
BC Racing BR Series Coilovers GT86 £600 Was on the car for around 8k miles Seems like the top mount has been cut a bit. Doesn't seem to have any effect on the performance though. https://imgur.com/a/JVxFMyp Ideally collection from Warwick
Hi, I've bought myself a 4 in 1 gauge I've got everything else working but I don't know where to tap into for the boost/vacuum reading. Has anyone got some advice or any pictures? Would greatly appreciate it!
GT86 Turbo Kit & BRZ Turbo Kit from Tuning Developments
Lewis Hashbrown replied to Mike@TD.co.uk's topic in Tuning Developments
Just a quick video I managed to record to show the sound! -
Has anyone ever installed a DEPO 4 in 1 gauge to there gt86? Just want to make sure all the supplied sensors are the correct size to bolt into a oil sandwich plate and tap into a boost line https://m.ebay.co.uk/itm/DEPO-60mm-Boost-Turbo-volt-oil-pressure-oil-temperature-gauge-4-in-1-PSI-C/332305763989?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20171010182220%26meid%3Ddee939040c7248b691f1f1d65b439a8c%26pid%3D100891%26rk%3D5%26rkt%3D12%26mehot%3Dlo%26sd%3D331934348983%26itm%3D332305763989&_trksid=p2056116.c100891.m5206
Lewis Hashbrown reacted to a post in a topic: GT86 Turbo Kit & BRZ Turbo Kit from Tuning Developments
That's what I love about mine 😂 just wondering if I'd get kicked off at a track day -
Yea that makes sense, was just wondering for track use. Don't imagine it would be to bad since its facing the ground -
Does anyone know how loud the car is with the screamer pipe? Like a decibel reading -
Special Offers From Tuning Developments
I can vouch for the stage 1 Turbo! Absolutely transformed the car. Plus who doesn't want a screamer pipe 😂- 6 replies
- power
- tuning developments
(and 7 more)
Lewis Hashbrown replied to Lewis Hashbrown's topic in Requests & Issues
Was a good read! Looks like that is more for the gear changes then to add to the feel of the clutch? Will still probably buy the spring though! -
Got a gt86 couple weeks ago and I'm loving it but I just can't get use to how the clutch feels (well lack of feel). I'm sure it's a bit of me being in a different car then what I'm use to and also the setup of the car. After two weeks I'm starting to get use to it but if is there a way to change it I would love to do it. I've seen in another thread that people raise/lower the clutch and some take out the spring as well? Has anyone here tried that? Basically I just want to be able to feel the clutch more when it gets near the biting point
