Jay Bamrah 29 Report post Posted July 6, 2021 I have a TD UEL NA TUNE, would my chances of passing emissions increase if I go onto the valet tune. 2016 Subaru BRZ 35k miles on it catless TD UEL+ overpipe stock everything else thanks guys Share this post Link to post Share on other sites
GravelRash 62 Report post Posted July 6, 2021 I don't think so. Valet mode stops the car from revving so there's no hoonage. The MOT emission checks are done at idle. AFAIUI remaps use the stock ECU for idle control and only really do their thing higher up the rev ranges when fueling and ignition need to be adjusted. 1 Jay Bamrah reacted to this Share this post Link to post Share on other sites
Luke 193 Report post Posted July 6, 2021 Biggest bit of advice is make sure the cat is really warmed up before it goes through emission checks as you’ve not got the primary cat the secondary cat needs to be warmed up by running the engine. 2 1 Jay Bamrah, Tom21 and MartinT reacted to this Share this post Link to post Share on other sites
Tom21 10 Report post Posted July 10, 2021 I think emissions are usually measured at idle and also at load, around 2750rpm. Our cars are usually quite close to the limit from standard, so yeah make sure it's warm. Sent from my Pixel 5 using Tapatalk Share this post Link to post Share on other sites
