Mattie941 1 Report post Posted January 20, 2020 Hi guys, The characterful GT86 is oozing it's personality again. It's got a problem with the windows. I can't lower the passenger side window from the drivers door switch. The passenger windows works fine with the passenger door switch. The passenger door windows is working fine when I open and close the door. However, when I open the drivers door, the window lowers and when I close the door it doesn't go back up. The window switches in the drivers door are also flashing intermittently. Any ideas guys? Cheers, Matt Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 20, 2020 5 minutes ago, Mattie941 said: Hi guys, The characterful GT86 is oozing it's personality again. It's got a problem with the windows. I can't lower the passenger side window from the drivers door switch. The passenger windows works fine with the passenger door switch. The passenger door windows is working fine when I open and close the door. However, when I open the drivers door, the window lowers and when I close the door it doesn't go back up. The window switches in the passenger door are also flashing intermittently. Any ideas guys? Cheers, Matt The protection mechanism has tripped out (usually due to the window freezing). It's a really common issue - if you search on the forum you will find the reset procedure which involves holding the window switches down for 10 seconds if I remember correctly 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted January 20, 2020 Really common when it's icy. With doors closed, hold down both window switches for ten seconds and then the same on the way up. 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Mattie941 1 Report post Posted January 20, 2020 Sorted. Thanks for the tips 1 Lauren reacted to this Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted January 21, 2020 There is some stuff you can buy on eBay which you can put on all the rubber around the window frame which will stop the glass sticking to the rubber, but just need to remember to use it when Frost is expected! Share this post Link to post Share on other sites
Lauren 2259 Report post Posted January 21, 2020 Another tip is lukewarm water on the seal where the window joins the door until you hear it give. That's where it tends to stick. You can put silicone spray on the rubbers which does help, though I just do the former these days. Share this post Link to post Share on other sites
3card 14 Report post Posted January 21, 2020 I had the same problem for the 1st time yesterday. With mine it was the passenger switch that was flashing so after googling it i found that i opened the window and when closing it i held the button in the up position for another 10 seconds after the window shut and it was back to normal 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
Church 209 Report post Posted January 21, 2020 You didn't do same at fully lowered position? Then it looks like procedure known to me may have excessive steps too Share this post Link to post Share on other sites
3card 14 Report post Posted January 21, 2020 26 minutes ago, Church said: You didn't do same at fully lowered position? Then it looks like procedure known to me may have excessive steps too No I just fully opened the window then closed it and held the button Share this post Link to post Share on other sites
Test Drives Unlimited 278 Report post Posted January 21, 2020 This is the stuff I use on my car 1 Angelina reacted to this Share this post Link to post Share on other sites
Angelina 82 Report post Posted January 21, 2020 This is the stuff I use on my car Use it on mine and hubby’s, never had a problem. That reminded me to do it tomorrow. Sent from my iPad using Tapatalk 1 Test Drives Unlimited reacted to this Share this post Link to post Share on other sites
