TTR 509 Report post Posted June 6, 2019 So, with some fair consideration I've decided I definitely cannot be arsed to spend the extra £10k or so to sort out my GT86 as I'd rather go on holiday and start racing again. So, with that I'd like to sell my Forged engine. Hasn't been run in completely yet and it's done 10 miles or so just running up and down the road. Spec is as follows: Carrillo 86.5mm 10:1 CR Pistons (Heads have been skimmed and block machined to clear the larger pistons) Bridgeway Billet 4340 I-Beam Con Rods Cosworth 0.78mm Head gaskets King Racing main bearings King Racing Con Rod bearings Cosworth Sump Baffle plate Mishomoto baffled oil catch can New FA20 Crank shaft New lambda sensor New air mass meter New throttle body New starter motor New oil pump and timing housing New high pressure fuel pump New port injectors New direct injectors (currently on back order waiting to be fitted, hence the CEL) Many other miscellaneous bits. Can provide receipts to prove the nearly £10k worth of parts and labour that's gone into the engine 🤮. Receipts include some comedy about me buying/selling things and being generally fickle. Price is to swap for your standard motor, with a full service history. Happy to go splits on labour cost to swap/remove engines. Car is currently in Milton Keynes. 20181121_163224[1239].mp4 Share this post Link to post Share on other sites
Lmc 27 Report post Posted June 6, 2019 Who did the rebuild? Share this post Link to post Share on other sites
TTR 509 Report post Posted June 6, 2019 3 minutes ago, Lmc said: Who did the rebuild? Company in Buckingham called Bay Automotive. Share this post Link to post Share on other sites
TTR 509 Report post Posted July 14, 2019 So since this has been sitting here for a while, I'm open to sensible offers. Share this post Link to post Share on other sites
DevilsCry 11 Report post Posted May 30, 2020 This is going to be a long shot since your post was from 2019.. do you still have the forged engine? Share this post Link to post Share on other sites
