JohnM 25 Report post Posted March 15, 2019 Has anybody come across the following issue with setting the alarm. After a long run out of over 10 minutes when I try to set the alarm I get a continuous single tone to which I have to deactivate the alarm, open the boot, shut the boot and then set the alarm. This happens even when the boot has not been opened during the trip out. Its pretty much happening every time now since i have had the car. Share this post Link to post Share on other sites
Ignited 24 Report post Posted March 16, 2019 I recently had an issue when I got a beeping a few seconds after setting the alarm. If I opened and shut the boot it worked ok. It turned out to be the alarm button under the front bonnet which had been bent down as the bracket is made out of chocolate! I just bent it up and made sure the cap on the bonnet was still in the right place to hit the button and problem solved. No idea why opening the boot seems to help but you problem sounds like mine so hopefully just a few minutes should sort it out. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted March 16, 2019 I've ended up cable tying the bonnet sensor down so it's never activated. Means I can lock the car and leave the battery charger on it as well 😂 I reckon that's the culprit though. Share this post Link to post Share on other sites
