Leeky
TAS300 AV input with CarSolutions cable?
Hey peeps,
I bought one of these so that i could get video input on my oem headunit. But i only get audio and not video. Anyone else tried these cables?
Is there a trick to getting it to work or perhaps do I just have a duff cable?
https://car-solutions.com/en/video-cable-for-toyota-touch-2-entune-monitors.php
I've tried a number of games consoles, iphone, fire stick etc but none display a picture; only audio.
Probably it is worth going trough the hidden menu. Put the car in Ignition ON press and hold SETUP and turn on and off the headlights 3 times. It could give you an option to enable the video from there. In the sources screen look if you have a VIDEO option.
P.S. I am just doing guesswork here so can't guarantee it is working :D
I already have a the AV menu option as soon as i plug the cable in. But thanks anyway.
9 minutes ago, Church said:
Isn't video input often restricted depending on car state? As in it should be parked/handbrake on and such?
No, not with this cable.
Ok so i got the video input working.
There is an SPD wire that is supposed to be disconnect. Turns out this isnt enough alone as i had to put on the handbrake to get the video to come to life. I know the headunit looks for a signal from the vehicle speed sender so I believe this SPD wire is the one the headunit uses to monitor that.
All i need to do now is follow the wires from the handbrake to the headunit then permanently earth it to the headunit.
Will post up a how to guide once ive cracked it.
