Leeky 84 Report post Posted August 16, 2017 Hey peeps, I bought one of these so that i could get video input on my oem headunit. But i only get audio and not video. Anyone else tried these cables? Is there a trick to getting it to work or perhaps do I just have a duff cable? https://car-solutions.com/en/video-cable-for-toyota-touch-2-entune-monitors.php I've tried a number of games consoles, iphone, fire stick etc but none display a picture; only audio. Share this post Link to post Share on other sites
vanko25 70 Report post Posted August 16, 2017 Probably it is worth going trough the hidden menu. Put the car in Ignition ON press and hold SETUP and turn on and off the headlights 3 times. It could give you an option to enable the video from there. In the sources screen look if you have a VIDEO option. P.S. I am just doing guesswork here so can't guarantee it is working Share this post Link to post Share on other sites
Church 209 Report post Posted August 16, 2017 Isn't video input often restricted depending on car state? As in it should be parked/handbrake on and such? Share this post Link to post Share on other sites
Leeky 84 Report post Posted August 16, 2017 35 minutes ago, vanko25 said: Probably it is worth going trough the hidden menu. Put the car in Ignition ON press and hold SETUP and turn on and off the headlights 3 times. It could give you an option to enable the video from there. In the sources screen look if you have a VIDEO option. P.S. I am just doing guesswork here so can't guarantee it is working I already have a the AV menu option as soon as i plug the cable in. But thanks anyway. Share this post Link to post Share on other sites
Leeky 84 Report post Posted August 16, 2017 9 minutes ago, Church said: Isn't video input often restricted depending on car state? As in it should be parked/handbrake on and such? No, not with this cable. Share this post Link to post Share on other sites
Leeky 84 Report post Posted August 18, 2017 Ok so i got the video input working. There is an SPD wire that is supposed to be disconnect. Turns out this isnt enough alone as i had to put on the handbrake to get the video to come to life. I know the headunit looks for a signal from the vehicle speed sender so I believe this SPD wire is the one the headunit uses to monitor that. All i need to do now is follow the wires from the handbrake to the headunit then permanently earth it to the headunit. Will post up a how to guide once ive cracked it. Share this post Link to post Share on other sites
