Andrew Smith 156 Report post Posted May 27, 2016 I am just trying to figure out what class my car would fall in to as my final drive and ally prop shaft are not listed as acceptable mods for street. Any ideas? Cheers A Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 27, 2016 If it doesn't say no to them then they are allowed. I can't see any mention of the above in sections S & G so N1 Street (Assuming you are N/A) Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted May 27, 2016 Hi Rob, yes N/A. Everything I have had done puts me in N1 Street. My shaft and FD are the only grey areas. Ill go with you, they aren't mentioned so they are good. I can't do Woodbridge but Anglesey should be ok if I can get a pass out Cheers A Share this post Link to post Share on other sites
Jamie_GRMN 177 Report post Posted May 27, 2016 I'm sure Kev had his final drive changed and he's still N1 Street so you'll be fine in there 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 27, 2016 If you're still Skeptical it's worth sending @Adrian - tss a PM for clarification. It may be the case that it does plonk you in to Pro but if that's the case the regs need to clarify that. The regs are fairly ironed out now though and I have an alloy prop in my room to go on myself and don't expect to end up in Pro because of it. Share this post Link to post Share on other sites
KevinA 695 Report post Posted May 27, 2016 N1 street for you no probs. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted May 27, 2016 7 minutes ago, rob275 said: If you're still Skeptical it's worth sending @Adrian - tss a PM for clarification. It may be the case that it does plonk you in to Pro but if that's the case the regs need to clarify that. The regs are fairly ironed out now though and I have an alloy prop in my room to go on myself and don't expect to end up in Pro because of it. PM sent, I will let you know Rob Share this post Link to post Share on other sites
Keethos 842 Report post Posted May 27, 2016 Yeah N1 I'd imagine, final drive shouldn't be a problem but I don't know about the prop shaft. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted May 27, 2016 N1 Street, the only class for GT86's really. Basically if it's not totally standard it's N1 Street and these rules would apply to you here. Stan ran a carbon propshaft in N1 Street the year before last. Kev runs a shorter final drive and Stan did too when he was in the same class, so there's your answer. 1 Andrew Smith reacted to this Share this post Link to post Share on other sites
Andrew Smith 156 Report post Posted May 27, 2016 4 minutes ago, Lauren said: N1 Street, the only class for GT86's really. Basically if it's not totally standard it's N1 Street and these rules would apply to you here. Stan ran a carbon propshaft in N1 Street the year before last. Kev runs a shorter final drive and Stan did to when he was in the same class, so there's your answer. Thanks Lauren, N1 it is then. Looking forward to getting involved Share this post Link to post Share on other sites
