Tweedbean 151 Report post Posted May 21, 2015 Good afternoon all, for all those that have lowered their GT86, I wondered what droplinks you had switched to? My stock ones were cut off when fitting coilovers, as the allen key hole to lock the thread in place when undoing these rounded off, therefore I am currently running without. I wanted to check I was right in thinking I need to go shorter and the amount I go shorter by is determined by how much I have lowered the car? For example, if I lower the car by 30mm, the drop links need to be 30mm shorter? I did have some stock ones on order but decided I wanted to steer clear as they rounded way to easily on both sides and its always good to have adjustable ones to assist in an eventual suspension set up once I have uprated other components. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted May 21, 2015 Whiteline make some. I used the ones that came with my coilovers when I fitted mine. Share this post Link to post Share on other sites
Tweedbean 151 Report post Posted May 21, 2015 Whiteline make some. I used the ones that came with my coilovers when I fitted mine. Thanks, yes I did fit some Whiteline ones we had in the garage but they were too long and caused the roll bar to hit the wishbone(may not be the right name) so they were whipped straight off. A friend has an account with them so may be the route I go. Share this post Link to post Share on other sites
Keethos 842 Report post Posted May 21, 2015 I'm using BC's supplied by Adrian at Fensport (after they had to double check with BC that they were allowed to sell them separately). If you message Toyokid, he might still have a spare set that he brought. 1 Tweedbean reacted to this Share this post Link to post Share on other sites
Guest Report post Posted May 22, 2015 If you're really stuck send me what you have and I'll shorten them for you to tide you over. Share this post Link to post Share on other sites
