Twigman 93 Report post Posted May 12, 2014 Could anyone explain or show me how to remove the interior door handle trims please? Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 12, 2014 Pull them off best to prise it from the bottom. 1 Twigman reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted May 12, 2014 The silver bits?They just pull off?They feel a bit fragile to be doing that!Are you sure? Share this post Link to post Share on other sites
rob275 1817 Report post Posted May 12, 2014 Positive, if i'm wrong i'll buy you a new set! 1 Twigman reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted May 12, 2014 Just seen a vid on youtube confirming..... doing my homework before my audio install..... Share this post Link to post Share on other sites
Keethos 842 Report post Posted May 12, 2014 Rob is correct, start to pull up from the underside of the door handle bit as at the top of the trim actually hooks upwards so you do need to hinge it outwards from the bottom. To remove the the door trim card itself, you need to remove the plastic pop rivet at the front and remove the 3 (I think) screws, 2 in the door handle after you remove the door hand trim and 1 where the door leaver is (behind a plastic cover cap). Then get your fingers under the door along the bottom and simply pry up and outwards all the way round. Once the door card is hinged outwards from the bottom, you can lift / unhook the top of the door car from the window sill. 1 Twigman reacted to this Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted May 12, 2014 Do not remove the silver door trim as shown in the video above the guys a retard, use the small gap at the base of the handle. 2 rob275 and Twigman reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted May 12, 2014 thanks all ...so the window/doorlock control/mirror control panel....that comes away with the door card does it? I assume it has a plug into the loom behind does it? - that I will need to disconnect Sorry for all the dumb questions but forewarned is forearmed as they say Share this post Link to post Share on other sites
Keethos 842 Report post Posted May 12, 2014 That's correct Twigman, there is also 2 cables across the door car that connects to the door release and the safety lock that needs unhooking (I think it's 2 cables or it might just be the 1) as well as another wiring loom towards the rear/bottom of the door card that connects to the inside door light. 1 Twigman reacted to this Share this post Link to post Share on other sites
