Mark@Abbey M/S 235 Report post Posted November 1, 2013 Rob, ring me on Monday I will talk you through it. Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 3, 2013 Rob, ring me on Monday I will talk you through it. Will do, I think i need to book my car in also, my Nearside link is catching on the inner arch. I don't get why it's only on one side but i don't get suspension. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted November 3, 2013 Instructions: https://www.p3cars.com/frz-install/ Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 4, 2013 Instructions: https://www.p3cars.com/frz-install/ I have the instructions, I just can't be arsed to read them. It's not the manly thing to do Share this post Link to post Share on other sites
keelerad 256 Report post Posted November 4, 2013 I love reading instructons, maybe I'm just twisted ALec Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 5, 2013 Having this plugged into the OBD2 port does it in get in the way of your leg ? Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 5, 2013 nope, the cable is right angled so you can't even see it. Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 5, 2013 Sorry more questions Will this read up to 7psi for boost ? Share this post Link to post Share on other sites
Kodename47 446 Report post Posted November 5, 2013 Will show exactly what your ECU MAP sensor reads. So if your MAP sensor reads that high and is scaled correctly in the ECU, yes. You can always run a separate analogue boost sensor and manually configure it in the gauge. 1 Mark@Abbey M/S reacted to this Share this post Link to post Share on other sites
Mark@Abbey M/S 235 Report post Posted November 5, 2013 The gauges can either read boost from stock map sensor if the car has been configured to run a 3 bar map sensor. They can also be supplied with a seperate boost sensor as well. 1st 6 supplied gauges all had the seperate map sensors supplied FOC Any questions ask away guys. Oil pressure sensor nearly sorted as well. Mark Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 5, 2013 Shame you don't have stock, I should of looked into this earlier Share this post Link to post Share on other sites
Mark@Abbey M/S 235 Report post Posted November 6, 2013 Shame you don't have stock, I should of looked into this earlier I do have stock again today; sorry Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 6, 2013 I'll have one then please mark Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 7, 2013 If this is going to be fitted to my turbo car does it need to be setup during Adrian's mapping or can I just fit it after ? Share this post Link to post Share on other sites
Pitman 188 Report post Posted November 7, 2013 As the gauge plugs into the OBD port, you should be able to fit it afterwards. Share this post Link to post Share on other sites
GT86-Ian 351 Report post Posted November 7, 2013 Thanks Dave, I've ordered one for delivery to fensport tomorrow Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 7, 2013 Thanks Dave, I've ordered one for delivery to fensport tomorrow Don't forget to get the dimmer done also, Green wire spliced to the Purple! Share this post Link to post Share on other sites
