Otintwee
About Otintwee
Glasgow
Bit late to the party, but have you still got the sports cat?
You can take the car to the dealer who can erase all keys using the global techstream, except the one you have left all you then need is a new fob and it reprogrammed, but unfortunately the key blade still allows access to drivers door lock.
- 10 replies
And a cheap way of lowering your car as well;-)
You align the blue marker on the chain with the mark on the crank gear starting on the left bank first, that is the right if you look from the front, the pink links line up with the engraved lines on the vvt gears it is worth noting that the crank key should be at eleven o clockish in line with the boss for the timing chain cover, once this is done you must turn the engine until the two diamond marks align on the vvt gears you can then fit the chain on the right bank at this point if you don't do this the timing will be 180 degrees out and the engine will not start, also on the crank gear there are marks on both sides,this allows gear to be fitted 2x ways only use the front mark to set your timing
That's how we diagnose accessory parking sensors other than the landcruisers etc when they can be put in diagnostic mode
Hi, you can get the dealer to program in a second set as well as the originals all you need is the codes from each sensor, on a side note the ecu will pick them up irrespective of where they are mounted on the car.
I am sure that if the sensors were fitted at pdi then you are covered for the same as the rest of the car by what you are describing it is either a sensor or wiring fault, if you put the ignition on and in reverse, wet your finger and lightly touch each sensor that should identify the faulty sensor.
Thanks guys, wanted to know if there was an issue with 235's before fitting them if so would have got 225's. Thanks again..
I know this has been done to death,but I can't seem to find the information I am looking for, my question is, I have just ordered a set of bola b1 in gunmetal for my black gt86, 18x8.5 et40, I have 235/40/18 tyres already. will these fit or do I need a different tyre size? Again sorry for dragging this up again..
Otintwee started following My new car
Just ordered smoked valeni tail lamps planning on new wheels, already bought reverse camera, but not had the time to install it yet.also going to get glass tinted.
Just took delivery of my 2015 black gt86 been looking for the right car for a while and now looking forward to spending even more money on it and working on it myself but being a Toyota master technician should make things a bit easier glad to be a new member..
