Andy Gside 4 Report post Posted January 27, 2022 Pulled up on the driveway after driving home from work noticed a relatively loud "CLICK CLICK" after switching ignition off. You can hear on the video, did some brief searching on Google didn't really find much other than its possiblely ac releasing pressure? Wondering if anyone else had had this before, the car in general seems fine check everything no fluid leaks or loose parts ect... Any help is appreciated 👌 20220127_160409.mp4 Share this post Link to post Share on other sites
Leeky 84 Report post Posted January 27, 2022 Sounds like an old dot matrix printer… I’ve never heard an 86 make that sound before. Can you get someone else to switch it off and see if you are able to feel/hear where its coming from? Sounds to me like the throttle body. Have you recently had the battery disconnected? Also its quite loud/clattering before you switched it off. Almost diesel like. Has it always been like that? Share this post Link to post Share on other sites
Andy Gside 4 Report post Posted January 27, 2022 17 minutes ago, Leeky said: Sounds like an old dot matrix printer… I’ve never heard an 86 make that sound before. Can you get someone else to switch it off and see if you are able to feel/hear where its coming from? Sounds to me like the throttle body. Have you recently had the battery disconnected? Also its quite loud/clattering before you switched it off. Almost diesel like. Has it always been like that? Yeah its an odd one..... ive had it on and off about 20 times it does sound like the throttle body.... i swapped battery over maybe a week ago... From what i can remeber yes, maybe sounds louder because of the audio quality!! Share this post Link to post Share on other sites
Rich196 103 Report post Posted January 27, 2022 Electronic sound is definitely the throttle body. This hiss, I think mine does this, not sure what it is, whether its the AC, or the vacuum system draining. 1 Andy Gside reacted to this Share this post Link to post Share on other sites
Andy Gside 4 Report post Posted January 28, 2022 Quick update just drove to work (steadily) driving everything felt normal & sounded normal no new noises or anything.... Got to work, shut car off and didn't make the clicks / hiss.... maybe like @Rich196 said was just ac draining... will keep updated if comes back ect.... Share this post Link to post Share on other sites
