Gt86life 0 Report post Posted February 9, 2018 What size speakers do I need for the front speaker and tweeter and the back speakers. Ive been searching but can't find a real clear answer Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
vanko25 70 Report post Posted February 9, 2018 Front speakers are 6.5 inch and rears are 3 inch if not wrong. You can get the Focal IS165TOY kit for the front. It is direct fit with no splicing or adapters needed and are relatively cheap. If you want something with higher quality you can look at Lauren's build. There were some other people with Hi Fi builds too. Share this post Link to post Share on other sites
Gt86life 0 Report post Posted February 9, 2018 Front speakers are 6.5 inch and rears are 3 inch if not wrong. You can get the Focal IS165TOY kit for the front. It is direct fit with no splicing or adapters needed and are relatively cheap. If you want something with higher quality you can look at Lauren's build. There were some other people with Hi Fi builds too. Thank you, will these speaker have good base to themSent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
Kodename47 446 Report post Posted February 9, 2018 48 minutes ago, Gt86life said: Thank you, will these speaker have good base to them All speaker bases are made of metal magnets..... 1 1 Deanusrjm and Varelco reacted to this Share this post Link to post Share on other sites
Gary p 46 Report post Posted February 9, 2018 Yeah fronts are 6.5 inch I also have 6.5 in back as well. Highly recommend sound deadening in all over. The rear speakers are like in an endless void. I know it adds wait but I got the back boarded out with plywood sound deadening Share this post Link to post Share on other sites
Gt86life 0 Report post Posted February 9, 2018 Yeah fronts are 6.5 inch I also have 6.5 in back as well. Highly recommend sound deadening in all over. The rear speakers are like in an endless void. I know it adds wait but I got the back boarded out with plywood sound deadening Am only going to change up the fronts and see how they sound. I did read about the sound deadening. I will defo add someSent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
Gt86life 0 Report post Posted February 9, 2018 Yeah fronts are 6.5 inch I also have 6.5 in back as well. Highly recommend sound deadening in all over. The rear speakers are like in an endless void. I know it adds wait but I got the back boarded out with plywood sound deadening What sound deadening did you used Because i want to use inside the door trim Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
Gary p 46 Report post Posted February 9, 2018 @Gt86life I used dynamat sound deadening. To be onest you only need to change the fronts. It will be plenty loud enough with good speakers. Iam running JL AUDIO C3 in front and JL TR in back as the back are running off headunit not separate amp. Share this post Link to post Share on other sites
