Nemesis
Accessory wiring
I want to add a car cam & phone charger & I’m not sure the best place to get power for them as I want them hard wired, I think it would be best to fit a small fuse box rather than use fuse taps as I have the option to add other accessories later. In past cars I took a tap from the main accessory cable on the ignition switch on the steering column but as I have a starter button I don’t know where I should tap the cable. I have a couple of 12v to 5v usb converters I can wire in so I can just use usb to micro usb cables instead of cutting the supplied cigarette adaptor
Phil - there is a cigarette socket in the glovebox as already stated.
I got a 2x 2a usb plug and that powers my current dashcam nicely from there. I have another one in the centre armrest which has the leads for my 2 phones plugged in.
The dashcam cable easily tucks in the roof lining and then slides down the inner pillar cover - just pull it down a little to miss the airbag. I then fed it down the inner door trim and then popped the side of the glovebox off and tucked it through to plug in to the lighter socket.
