Deacon 1357 Report post Posted June 9, 2017 Hello, My Motons are for sale. They will be off the car and available in around 8 weeks. They have been on the car for about 12 months and have covered approximately 6000 miles. During that time I have worked with Moton to make them a good road, and fantastic track, set up. They are fitted with 7kg front and 8kg rear springs (both plus helpers) and include AST topmounts front and rear. The dampers alone are £3450 plus top mounts + springs from Moton. I've included the information on them from Moton below:- Moton 2-Way Sport The Sport line is designed for the serious club racer and high performance street driver. This ultimate suspension system is by far the finest quality and best handling suspension system on the market today. Featuring remote reservoirs for superior fluid temperature control, quick release hydraulic lines (on most models) for easy installation, separate compression and rebound damper valving adjustment and height adjustable spring perches, this kit is beyond the more common coil-over systems on the market. If your driving can benefit for the ultimate in suspension tuning, then this kit is for you. What do we have in store for you? Specifications The Moton Sport damper features 15 positions of bump adjustment on the remote reservoir and 15 positions of rebound on top of the piston rod. Each adjustment done to the damper is very noticeable to the driver. Our Moton Sport dampers are designed to be uncomplicated, easy to use and to deliver the absolute best performance. The Sport dampers perform really well at low speed as well as high speed velocities which gives you total control regardless of the conditions. The reservoir is connected by a high pressure hose and is equipped with swivel banjo’s for easy installation of the canisters in the car regardless of the position. The damper bodies are produced from the highest quality steel or aluminum. The shaft are induction hardened and chrome plated. The canister pressure can be varied between 6 - 18 bar (100 - 300 psi) to help support the car in high speed cornering with soft springs. Benefits include Comfortable on daily roads Easy to adjust to a real race setup Easy to work with Every single adjustment done is very noticable to the driver Proven reliability Wide range of spring rates can be used Improved platform stability Improved traction, higher grip level Improved curb stone and bumpy track control Improved tyre wear Features Seperate Bump (15) and rebound (15) control Ride height adjustable Unique blow off valve system in remote reservoirs Large piston rod diameter for more fluid displacement Adjustable gas pressure for added lifting forceLarge main piston for quick response Large main piston for quick response No preloaded valve stacks needed for low speed damping control Swivel banjo hoses for easy installation of remote reservoirs Here is a picture when they were fitted to the car:- And here is the most recent picture I have of one off the car (from February this year):- I'm looking for £2000 collected so a massive saving over the new price for some of the finest dampers available. I'm located on the West Midlands / Staffordshire boarder but also regularly travel to Bedford and Cheltenham. I'm also at many of the club meets. Any questions please ask ☺ Share this post Link to post Share on other sites
AJ124 118 Report post Posted June 9, 2017 Whats the reason behind the sale? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 3 minutes ago, AJ124 said: Whats the reason behind the sale? I've been involved in the development of something else which is now going forwards. While I can justify multiple sets of wheels to the gf multiple sets of suspension is harder! 😂 2 AJ124 and surrey86 reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted June 9, 2017 I'm trying to think what could possibly top these 2 Rich and Deacon reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 43 minutes ago, Ade said: I'm trying to think what could possibly top these The Motons are definitely an awesome suspension set up that's for sure! Share this post Link to post Share on other sites
KevinA 695 Report post Posted June 9, 2017 I'm trying to think why ? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 26 minutes ago, KevinA said: I'm trying to think why ? Why I'm changing? Share this post Link to post Share on other sites
KevinA 695 Report post Posted June 9, 2017 Thought the motons were perfect for your needs, you must have been enticed by something special. Now you'll have Lauren to answer to Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 51 minutes ago, KevinA said: Thought the motons were perfect for your needs, you must have been enticed by something special. Now you'll have Lauren to answer to You've hit the nail on the head with something special. The Motons are an amazing quality item and these should be a step further on. Share this post Link to post Share on other sites
Ade 517 Report post Posted June 9, 2017 51 minutes ago, KevinA said: Thought the motons were perfect for your needs, you must have been enticed by something special. Now you'll have Lauren to answer to You've hit the nail on the head with something special. The Motons are an amazing quality item and these should be a step further on. I heard Nitron were looking for a development GT86 and offering massive discounts to anyone interested.... Sent from my SM-G935F using Tapatalk 1 surrey86 reacted to this Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 26 minutes ago, Ade said: I heard Nitron were looking for a development GT86 and offering massive discounts to anyone interested.... Sent from my SM-G935F using Tapatalk I'd class Nitron as at a similar level to Moton so wouldn't be a worthwhile swap for me. 1 Ade reacted to this Share this post Link to post Share on other sites
Ade 517 Report post Posted June 9, 2017 26 minutes ago, Ade said: I heard Nitron were looking for a development GT86 and offering massive discounts to anyone interested.... Sent from my SM-G935F using Tapatalk I'd class Nitron as at a similar level to Moton so wouldn't be a worthwhile swap for me. Hmmmm Ohlins ttx... but theyve already been developed by TMG.... bilstein MDS already developed by TMG.... Penske are developed by Raceseng... JZs Racecomp Engineering... Im stumped..... Sent from my SM-G935F using Tapatalk 1 Deacon reacted to this Share this post Link to post Share on other sites
Rich 378 Report post Posted June 9, 2017 How are these as a road setup? Drivable daily or more for a weekend warrior and track car? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted June 9, 2017 6 minutes ago, Rich said: How are these as a road setup? Drivable daily or more for a weekend warrior and track car? I use them for daily use as well but they're more biased towards weekend and track use than the Flex A's for instance. A big part of the time I've spent on them with Moton has been making them more daily friendly. As a bonus because they have sooooo much travel compared to a lot of other dampers they're excellent on big potholes, etc! 1 Rich reacted to this Share this post Link to post Share on other sites
