Deacon 1357 Report post Posted January 6, 2017 Does anyone know if the stock centre pipe will fit with an aftermarket (cobra in this case) back box? Post manifold fitting I'm looking to quieten my exhaust and this would seem a simple solution. If it works. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted January 6, 2017 Centre pipe, not the front pipe? If you mean the main part of the cat back, then no. Totally different. I know of no cat backs that are compatible as they route the pipework around the rear axle differently. If you mean FP, then it's a direct swap. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 6, 2017 19 minutes ago, knightryder said: Centre pipe, not the front pipe? If you mean the main part of the cat back, then no. Totally different. I know of no cat backs that are compatible as they route the pipework around the rear axle differently. If you mean FP, then it's a direct swap. Cheers Steve. It is the centre pipe I meant - I thought it was a long shot but figured it was worth the question 👍 Share this post Link to post Share on other sites
