Eleanor11 1 Report post Posted April 10, 2015 Hi, Has anyone else noticed that their rear demister is really slow? I know mine is working because I get the stripes, but its so slow. Thanks Share this post Link to post Share on other sites
Lauren 2259 Report post Posted April 10, 2015 No, not really, it depends upon how much water etc is on the rear screen. It can take 10 minutes to clear, but that is quite usual. Share this post Link to post Share on other sites
Eleanor11 1 Report post Posted April 10, 2015 Ug, must be just unlucky with mine then (the mirrors clear very quickly though so its not all bad) Share this post Link to post Share on other sites
rob275 1817 Report post Posted April 10, 2015 I recall one person having an issue with theirs, it was replaced under warranty. Share this post Link to post Share on other sites
JamesP1991 222 Report post Posted April 10, 2015 I think it just takes some time to clear. If there is a lot of moisture on the rear screen in the morning, mine normally takes about 10 minutes to fully clear! Bit of a pain if you need to reverse or see anything behind you though Share this post Link to post Share on other sites
Tareim 343 Report post Posted April 10, 2015 I think it just takes some time to clear. If there is a lot of moisture on the rear screen in the morning, mine normally takes about 10 minutes to fully clear! Bit of a pain if you need to reverse or see anything behind you though that's what the parking sensors are for, just keep reversing till the beep is solid Share this post Link to post Share on other sites
Lauren 2259 Report post Posted April 10, 2015 Just use your side mirrors to reverse, best way anyway. Share this post Link to post Share on other sites
adam 70 Report post Posted April 10, 2015 Run your car with the aircon on for a while and it should eventually take the moisture out of the inside of the car Share this post Link to post Share on other sites
