Deacon 1357 Report post Posted January 24, 2015 Bit random but I noticed there seems to be quite a big gap between the edge of the windscreen pillar and the wing since I've had a new screen fitted - wondering if they've 'forgotten' to re fit something. Does this look right? Share this post Link to post Share on other sites
Guest Report post Posted January 24, 2015 Does the wing fit well with the door?The wing itself and the top rail it's bolted to are very flimsy, and could probably be moved down if the fitters put some weight on the top of the wing?When I got my new car home I noticed the join between the front of the door and back of the wing was stepped. I simply pulled the wing out to line them up again. Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 24, 2015 Cheers Nigel I'll have a look Share this post Link to post Share on other sites
nikndel 509 Report post Posted January 24, 2015 If you are not sure is there a local dealer with one to compare? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 24, 2015 Sadly about 15 miles away is the nearest. Good call though. Share this post Link to post Share on other sites
Guest Report post Posted January 24, 2015 What does the nearside look like? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 24, 2015 Pretty much the same Nigel Share this post Link to post Share on other sites
nikndel 509 Report post Posted January 24, 2015 Always a good excuse for a drive out though Share this post Link to post Share on other sites
Captain Duff 79 Report post Posted January 25, 2015 This is mine, just taken (tried to get a similar angle). The actual gap between the pillar and wing panel is around 3-4mm if that helps? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted January 25, 2015 That's fantastic thank you! Really helpful :-) Share this post Link to post Share on other sites
